Help me open the door .....
davetrees
Post by davetrees »
I've struck a somewhat challenging problem ....
I was silly enough to lock the rear driver side door of the GB, and now it won't open/unlock (button moves up & down, but doesn't unlock the door - obviously the rigours of rallying are too much for the mechanism !) :banh:
Outside door handle won't release the lock, and I can't open it using the inside handle because the main hoop of the roll cage sits directly over it (good bit of design that ..... not ! :roll: ). Cage also precludes removing the door card to trip the lock from inside the door.
Only options I have come up with so far are :
- unbolt the hinges at the B-pillar (they are accessible with front door open) ... but not sure if this will allow enough movement to get at the inside handle; or
- take a holesaw to the door card from inside the car so I can get at the lock mechanism
Any other suggestions ?
DanTurboLancer
Re: Help me open the door .....
Post by DanTurboLancer »
Yeah mate just unbolt the door at the B pillar, it will just swing out using the latch at the back. :thumpsup:
davetrees
Post by davetrees »
That's what I'm hoping ..... but worried that it might bend (or otherwise damage) the latch ?
I had a similar problem with my GD sedan, I just kept working at the handle and inside locking knob and it eventually opened.
I know what has caused the problem.
There is a little spring that helps the lock to return to a position so it works properly. After time the spring rusts away or breaks.
davetrees
Post by davetrees »
Thanks Dave
Tried that ... but unfortunately the locking knob came off and the metal rod has flopped sideways inside the door so I can't get at it !
I'll try the hinge-removal method one night this week & see how I go.
(I had a similar problem a year or so ago with the RHF door, but was able to fix that easily as I could get the door card off)
Might have to go the Mr Bean option for the future ... :lol:
