Items needed for conversion??
Wanna convert my sigma to a 2.6 manual. Currently has a 2.0 auto...
wanna know what parts i need for the conversion..
as im aware;
-pedal box
-brake sleeve
-manual gearbox (got)
-2.6 (got)
-pajero power steering?
as im aware;
-pedal box
-brake sleeve
-2.6 (got)
Re: Items needed for conversion??
hole in the fire wall,
clutch cable,
hope the shifter hole lines up with the new gearbox
interior might be different too. i got myself a whold manual conversion set up at home i found the other day forgot i had it. its for a GJ scorpion . pedals, interior, clutch cable, the works
i'd leave the power steering to another time. do it seperate to avoid confusion and mixed thoughts as you need to swap the whole steering column and then you'd have different keys unless you swap all keys with it or swap the ignition barrel lol.
clutch cable,
oh. and the tail shaft i different i think as the 2.6 has a bigger spline?? i'm pretty sure. but need confermation
you WILL also need custom gearbox mount
manual tailshaft to suit
console surroound and gear boot
dont forget clutch and flywheel aswell
Why a custom gearbox mount? just use a manual jobbie?
There is one major thing you all forgot to say
"leave the farkin sigma alone and finish your coupe"
manual mount should just bolt in holes line up and everything too i think
Coupe requires alot of work.Galant_GT0 wrote:There is one major thing you all forgot to say
i wanna do something in the mean time that requires lil work.
The coupe requires rust work, and thats expensive shit if you cant do it yourself.
Therefore its on hold lol.
- amgis_obrut
I've got a clutch cable you can have
yer sweet
webby wrote:Why a custom gearbox mount? just use a manual jobbie?
ive done 2 auto to manual conversions using a 2L jap box and GJ/K sigmas.
the Auto body has the mount holes further forward than the manual.
also the trans tunnel is wider on the auto, so you get less space around the clutch than a manual bodyd car.
although they were early jap boxes from a GE/H the correct one may be longer? i dunno
- 81GL
Yeah, found the same as Billsy for all I've done; GE GH, even the GD didn't line with the holes, but as said, maybe with alternate gear box might work?Billsy wrote:webby wrote:Why a custom gearbox mount? just use a manual jobbie?
Yer, GJ-GN Jap boxes have longer extension housings than GE-GH boxes
the guy who did the manual conversion on my GJ used a GH 'box and mount. It all lines up fine as far as I can see apart from some interesting hackage to the front edge of the shifter hole
alright started ripping out the engine outta the galant...
gunna use the gearbox outta that aswell or use the other 5 speed i have, gunna grab that clutch cable off you mick...
then i need the mount?? which i think i have.
Need pedal box?? where could i locate one of these?? console surround and gear boot??
you need an offset rear mount as the auto is longer than the 5 spd jap out of a gj and the splines are bigger as well 2.6 borg 3 spd auto and i need the offset style mount for my gn any help would be nice.
Just buy a rusty old Sigma off Ebay and rip the parts off that. Then you'll have them all and some. Probably cheaper too?
- amgis_obrut
nice thread mine fellas
