temp and fuel gauges
crystalmeths
Post by crystalmeths »
hi all both the temperature and fuel gauges have died in my gj , I have replaced the fuel sender unit and the temperature sensor but still not working any help much appreciated thanks Chris.
Re: temp and fuel gauges
Broken wires??
Bad contacts???
have you checked with a 2nd guage (assuming you have one)
crystalmeths
I have checked the connections on the dash and the fuel sender and the temperature sensor
From memory, there is a 10v 3 pin regulator (LM7810) somewhere on the back of the dash.
If it has failed, you lose the Temp and Fuel gauges. These gauges require a regulated voltage to read correctly.
crystalmeths
thanks superscan do you get replacements at auto electricians ?
What about the circuit board behind the instrument cluster?
crystalmeths wrote:thanks superscan do you get replacements at auto electricians ?
Jaycar have the LM7809 (9volt) regulator, you just ad a 1n4004 diode to the ground pin to get 9.7V which is close enough for the gauges to read correctly.
You could also just use the LM7809 but the gauges would be slightly out.
If you need any help with the circuit etc, let me know.
crystalmeths
thanks again superscan :thumpsup:
turbosigma
Post by turbosigma »
InsaneTD
Post by InsaneTD »
How can you tell if this is starting to cause trouble?
Call me TD.
crystalmeths
with mine the fuel gauge just stopped working and the temperature gauge started to work only on and off for a couple of days then died
chriz312
Post by chriz312 »
Could that 3 pin regulator be the same problem for my gh sigma my fuel gauge and temp don't work but I haven't replaced anything yet...
crystalmeths
Chriz312 it is shear driver abuse that broke yours
Had fun finding my GJ workshop manual.
Here are a few pics.
Here is where the regulator is situated on the back of the dash.
This is a wiring diagram for the dash.
I have located a GJ dash and will confirm the pins are in the same order.
Left to right, looking at the writing on the case, pins facing down.
1=In (12volt)
2= Ground/earth
3=Out (10volt)
Back Plate= Ground/earth.
http://www.fairchildsemi.com/ds/LM/LM7805.pdf
Preferably use a heatsink.
I'll post some more tomorrow.
81GL
Post by 81GL »
Hey all.
From memory, these regs are 'clamped' onto the cluster aren't they?
Pretty sure I remember in my GH cleaning the contacts & it all worked fine again??
-A touch and go connection would explain the erratic operation most encounter. Although if both gauges are dead, then likely regulator has failed.
crystalmeths
Awesome Scott thanks mate :thumpsup:
