Hey Guys,
I need to order to a cap, points, rotor and condenser for my distributor which is stamped as T3T03874.
Can anyone confirm the part numbers?
Cheers,
Phil
T3T03874 Distributor part numbers
Re: T3T03874 Distributor part numbers
That's a Mitsubishi (rather than Bosch) dizzy ..... and is a 4G32 GC/GD vintage unit ? (I had the same in my GB, which had a late engine in it ... GB ran Bosch dizzy from factory)
Points = Bosch GM216 .... but GM210 also fit
Condenser = GM556
Cap = GM347
Haven't got the box the rotor came in .... but it will be whatever goes with the GM347 cap
You MAY have to change connectors where the condenser wire goes on to the points .... I have found that different brands have different connectors. No big deal to change though.
Condenser = GM556
Cap = GM347
Legend, thanks Davetrees!
