I thought I read some were that a magna tr/ts head will fit and was a good upgrade to a astron head
I have a Tritom MH 2.6l it is a old engine as still has carby was going to have it ported and polished larger valuves and beehive springs
my question is
is it easy to replace with the tr/ts head and better to do up the magna head or my trition head
Thanks
Chris
4g54 head
Re: 4g54 head
http://www.sigma-galant.com/viewtopic.php?f=30&t=3970
the problem you may have if you wont to stay with the carb inlet is the rear water outlet on a magna head is bigger that your inlet manifold may cover
Re: 4g54 head
Can I just cover the water outletcheaterparts wrote:http://www.sigma-galant.com/viewtopic.php?f=30&t=3970
Must be a way of making it fit and work
Re: 4g54 head
I had the same problem on a twin weber manifold that didn't cover the large rear water outletesky64 wrote: Can I just cover the water outlet
I welded a couple of pieces of aluminium flat to widen the contact area and machined the manifold mating surface flat again
Re: 4g54 head
Thanks cheaterparts
so would I be better to get the TR/TS head or do the work to the triton head
Re: 4g54 head
So could I just get a TR/TS inlet manifold and cut it and have well make one manifold out of two
