ok so i know there are different cams, but what do they mean haha?
just found a hydraulic cam for sale for 80 bucks for my g32b, and just wondered what the differenc is between my stock and the hydraulic one? if any?
i know there are hydraulic rockers, i know how they work, but can i use existing rockers on a hydraulic cam?
difference between cams
- DragonCypher
- Contact:
Re: difference between cams
I wouldnt think there is any difference between mechanical and hydraulic lifters
The cam lobes/rockers still run on the same type of slipper bearing surface and theres no reason why it would have different timing
jeez i hate to break up the dreaming and bad advise but mate if you dont know the
differance forget it now before it costs you more money
ps hyd cam are for girls get a man cam
cheers stealth
cheers stealth
- DragonCypher
- Contact:
I think the point here.. is whats the difference in the actual camshaftstealth wrote:jeez i hate to break up the dreaming and bad advise but mate if you dont know the
cheers stealth
The camshaft doesnt change, only the rockers with regards to hydraulic lifters, and manually adjustable tappets
[EDIT]
Just came across this:
That is, assuming the EXACT same camshaft is used for the different types of lifters.Rule of thumb, a solid lifter cam requires 10 degrees more of duration to operate in the same power curve as a hydraulic. From that point, a 220 degree hydraulic cam operates in the same rpm range as a 230 degree solid lifter unit.
Hydraulic lifters are slower to open the valve due to the damping from the oil.. hence the different timing
will not buy ahah
will not buy ahah
ok mate here a quick reveiw of what you havent learned yet
there are serveral different types of cams for eg
flat tappet
mechanical
hyd
hyd roller
mechanical roller
all the these cams are different ,different in the lobe shape,size and what thay
do
yes you can use a hyd roller with mechanical rockers but you can also kiss
you engine goodbye once you start it
mate im not being a smart arse here its just if you dont understand basic engine theory
there no point trying to learn on a forum
why not just have square lobes that way you can get perfect timing events?????
its not that simple and people spend many many years trying to understand cams!
all the average person can do is pick something thats tried and tested and bolt her
in time it and enjoy!
hope this helps without offending
cheers stealth
flat tappet
mechanical
hyd
hyd roller
mechanical roller
do
cheers stealth
- Rallyant
- Contact:
Have a good read of this (and all his articles for that matter) http://www.grapeaperacing.com/tech/valvetrain.pdf
Explains the pros and cons and practical uses for hyd vs mech vs roller etc.
Has all the info most people will ever need to know about cams.
stealth wrote:ok mate here a quick reveiw of what you havent learned yet
flat tappet
mechanical
hyd
hyd roller
mechanical roller
do
cheers stealth
cheerrss bud
now i know, thought it was simpler ;)
cheers mate, i no longer like hydraulics ;)Rallyant wrote:Have a good read of this (and all his articles for that matter) http://www.grapeaperacing.com/tech/valvetrain.pdf
