So, what do you suggest I do to the motor mod wise? (don't say turbo, I don't want to go down that road in this car)
I'm looking to build it up as a warm N/A motor. Nothing too wild as it's a daily driver but I would like to squeeze a few more neddies out of it.
I figured the way to go would be something along the lines of:
- A bigger throttle body (easy done as it's gotta be cut and shut onto the opposite end of the plenum, same as an Astron EFI setup)
Up the compression (is this a matter of swapping to Flat Top pistons or would it involve head work?)
Hotter cams (are there off the shelf items for 4G63 N/A or would it be custom, There's millions for the Turbo motor but I assume they wont work, right?)
There's so much info out there for the turbo motors as there's a huge following for them, but it seems not many people go the N/A option.
Oh and I'll try my best to document the conversion on here as much as possible.
I'm not looking for a nut and bolt how-to, just a pointer in which direction I should head.
