Modded 32 anyone?
Modded 32 anyone?
Hi all,
Just curious to if anyone has put a decent amount of coin into a 4g32 if so SHOW ME!!!! hahaha
- Rally_2.6LC
Re: Modded 32 anyone?
They all look like the same motor.....except worked ones are normally accompanied by twin webers and extractors, all teh coin is inside where we cant appreciate it.
Cheers Matt
Cheers Matt
^^^^Dude speaks the truth^^^^
If you were pull my Saturn down you could see where the rods have been ground and polished in the ballancing process, but that's about it. I guess you might notice the port matching if you pulled the manifolds off too. And yeah, twin carbs, extractors and a lumpy idle are a dead give-away Being left at the lights is a pretty sure sign too
T.
T.
John Ruskin
John Ruskin
hahaha you lot are funny im actually more after what people have done and how much power your making im well aware of internal mods not being visible im a mechanic hahaha
as far as money goes, no (but thats cause im very resourceful) but give me a couple of months and ill have a g32b running:
1mm oversize high comp pistons
ported head
stage 3 cam
twin webbers or dellortos (whichever i can get cheapest)
custom built extractors
custom 2 1/4inch exhaust
and ill chuck a full set of race bearings in it for peace of mind..
have no idea on power figures or anything (ill let you know when i know) all i do know is it should boogie in a stripped out LB, and if it doesnt there is always the turbo manifold waiting patiently in the garage.. turbo fed twin side draughts should be interesting..
ported head
stage 3 cam
^^rob beat me to it, that is my old turbo saturn engine, went as well as my stock starion turbo hahaha fair better than a saturn with side draft carbies etc. went well and was cheap to build!
^^that's a suck-through turbo setup, right?
is setting up a suckthrough turbo easy? like you just have to built custom exhaust manifold for the turbo to seat on, and bolt the carby infront of the turbo with adapter plate, redirecting the output of the turbo to the intake manifold, and voila!! how about the thing they called "water spray" on the turbo for the suckthrough setup?
cheers!
cheers!
Krohny yours will be a cranky bit of gear!!! that turbo set-up looks awesome!! any power figures? and how much boost you were running? yeah its a suck through set up and if your keen on water/metho injection its used to keep intake temps down under higher boost levels due to there being no cooler mind you intake temps do tend
to keep down more with a suck through setup due to fuel being in the intake boost charge. a mate of mine ran a l200 with a 4g63 and lpg turbo set up and he had to run it around 15 pound because it was starting to ping abit It was QUICK!!!
i used to boost it up to around 15psi. i reckon it was around 80/85rwkw. if i knew what i do now back then i could have had it going better.
i havent got the turbo kit on anything yet, but ive got a flojet pump i was gunna use for water injection
Id be happy with 85 rwkw for sure i plan on running 15-20psi but im running straight LPG and a t25 (for now) im VERY curious to how its going to perform with the set up im going to run Ive got a mate that runs a vl wagon on 22psi (N/A bottom end) with a hx 35 holset turbo. heres the vid http://www.youtube.com/watch?v=cfFsKOpxli8 it goes off
he is also setting up my galant
Most I got was 158rwhp....
ive got a simple mixer complex convertor lpg setup ive been playing with... havent decided what im gunna turbo with it yet
definately makes tuning far simpler though
every australian should get the lpg government rebate at least once too
What setup were you running hoonboy? Yeah i agree Rob ive got a bloke that will stamp the system so i can get the rebate lol
LPG turbo can be an awesome thing!!!
Twin cam head, 45mm webers, 1770cc's and a shot of nitrous
SHIT!! that would be a fun bit of gear!!!
