Anyone have or know of a good resource in the US for the front cover or bearing retainer? I need one quickly.
Front Bearing Retainer needed
Re: Front Bearing Retainer needed
No Idea but be careful as there are at least 2 types for the KM132 gearboxes, depending if you have the tapered roller lay shaft or the needle roller+ ball bearing lay shaft.
Superscan, thanks for the heads up - I believe I have the ball bearing version, as there are not tapered roller bearings in the front of my transmisson.
