Diff identification
Posted: Tue Dec 05, 2017 6:00 am
Hi
I’d like to change the diff ratio in my 1999 4x2 Triton ute, and I’m hoping a member here could help me identify which Mitsubishi differential I have, and from what vehicle to source a diff centre, fitted with a ratio, more to my liking.
According to my Triton owners’ manual, I currently have a 4.636:1 ratio diff, and I’d like to change to a much higher ratio, somewhere between 3.5:1 and 3.6:1, with a 3.9:1 or a 4.1:1 as a very last resort. If it could also be a LSD unit, that would be excellent.
I’m hoping someone here could identify the diff, without me having to strip it? As the ute is used daily.
I would've posted photos, but seems I can't load attachments on the forum, and I don't have an account with a picture hosting website.
I could add that the centre portion is held on with 10-bolts, and the centre portion to diff housing flange(not the propshaft flange) has an outside diameter of approximately 280mm, the bump on the rear of the diff housing has a diameter of approximately 230mm (9”). The diff has 256mm diameter brake drums, and is 1500mm in length (wheel mounting surface to wheel mounting surface).
Thanks in advance
Thanks in advance
