What large fuses, flasher cans or relays are needed for the 2nd fuse panel up under a scorpion or sigma dash. Its positioned above the accelerator pedal
Not the side fuse panel. I have no lights, accessories and I can't fire up the motor. So I'm assuming these are the culprits. Worse comes to worse i'll ditch the harness and fit one from a HK holden instead. I know its sacrilege to some but I'm on a pension and there easier to rewire up without being over complicated.
fuse or relays
Re: fuse or relays
looks like, either nobody knows or nobody is on here anymore... Will be a lot easier to sell this car and put the money to finish something that is 60s GM based and more deserving than being bothered to fix this type of automotive lemon.
Re: fuse or relays
Very difficult to go from memory.....my only suggestion really is to refer to the gregorys manual or if u are lucky enough to source one, a workshop manual for such a car
