Marty's GA Build
Posted: Sun Aug 12, 2018 2:29 am
by 71GA
I have owned this car for many years and whether i like it or not it has become a build/ project car. I purchased the 1971 GA Galant of a lady owner who bought it ex demo in Broken Hill and at some point moved to Adelaide. The car is pretty honest and a part from some minor front end damage (which had been repaired reasonably well) and a smallish amount of rust in the usual spots is not bad a for a 1971 car. The car was originally a 1300, drum brake, 4 speed car. After purchasing the car i swapped out the front drums for discs and installed new lowered suspension, lancer hatch steering wheel, venetian blind and Hayashi wheels. Even though it was a bit rough around the edges i really enjoyed using the car.
2015-01-25104241_zps5d690e4e by
martin sharpe, on Flickr
The next few post's will be a bit of a catch up to get me up to date.
Cheers,
Marty.
Re: Marty's GA Build
Posted: Sun Aug 12, 2018 3:10 am
by 71GA
The plan for the car was to keep it what i would call relatively original. So freshen up a 4g32, fit Jap 5 speed, repair the rust to the best of my abilities, body work and paint. Sounds easy when you condense it into one sentence
One of the first few things i started looking at was sourcing an engine. I ended up getting a bottom end from one of the guys off the forum and a cylinder head from a bloke in Tassie which had been ported and polished. A part from a few extra galleries in the block(can you spot them?) the motor went together pretty well.
4g32 identification by
20180713_142646 by
The motor has new rings, bearings, timing chain over sized pistons and has been balanced. It currently has a standard cam, 32/36 Weber and i'm in the process of modding some RPW headers to suit the large flange.
20170623_210015 by
20180410_172745 by
20180617_013121 by
Cheers,
Marty.
Posted: Wed Aug 15, 2018 6:07 pm
Very nice Marty,
Loving the look of this, just a simple lowering job and nice set of wheels is all these need to make them look good
How far do you think you'll go with paint? Whole car, or just try to patch up and blend any repair areas?
Posted: Wed Aug 15, 2018 10:13 pm
by 71GA
Thanks mate i appreciate it. I'm not really sure how far i'm going to go with the paint, i haven't had a lot of experience with painting but i'm definitely keen to learn so we will see how i go.
The next thing i started looking at was the various rust spots around the car. I did a bit of research on rust repairs and i think the most spots have come out reasonably well.
20170219_174358 by
20170219_182351 by
20170404_182002 by
20180522_140710 by
20180522_165301 by
20180531_125545 by
Both side heater channels have also been done but i don't have many photos of that.
Cheers,
Marty.
Posted: Thu Aug 16, 2018 7:24 am
by yno26galant
Good work marty. Check up near the battery tray i had some surface rust up near mine when i removed the tray from the engine bay
Posted: Thu Aug 16, 2018 5:44 pm
by 71GA
Thanks for that. I have noticed a bit of surface rust around the battery tray but it doesn't look like it should be anything too major.
Also i found a couple of pics of the heater vent channel repair.
Snapchat-448182047 by
2018-08-15_09-42-23 by
I would definitely recommend checking your heater channels as both of mine were bad.
Cheers,
Marty.
Posted: Thu Aug 30, 2018 11:52 pm
by 71GA
After the rust had been taken care of i stripped and painted all the inner guards and behind the grill will POR15. If you're not aware of POR15 it's an anti rust paint and claims to create a mechanical barrier to rust versus a chemical system most other brands use. It's pretty expensive but does go on pretty nice and sets very hard so we will see how it goes.
2018-05-07_10-40-33 by
20180602_163453 by
20180724_181751 by
I used a brush to apply it and think it came out reasonable.
Cheers,
Marty.
Posted: Fri Aug 31, 2018 7:52 am
by yno26galant
Looks awesome mate. the shine on the black is painted with a brush??? What brand is it ?
Posted: Sat Sep 01, 2018 10:52 pm
by Scorpma82
Yeah I've seen reviews of por15, none of them are -ve
Posted: Tue Sep 11, 2018 5:54 pm
There's some pretty decent rust repairs you've done there. Nice job
Posted: Mon Oct 01, 2018 2:03 pm
by 71GA
Cheers guys.
Next on the list of things to address is cleaning and painting the long list of bits and pieces.
GS/ GTO mirrors
Before
2018-10-01_12-26-00 by
After
20180723_145205 by
Other random bits
20180809_182900 by
There is still heaps of stuff to clean up and paint. Also one patch of rust in the chassis rail I've started to investigate.
20180810_142003 by
20180810_145633 by
Cheers,
Marty.
Posted: Mon Oct 01, 2018 4:52 pm
by tandanus
This is commendable work.
Great to see another GA being loved
Wish I had your welding abilities
How are you going with relocating the gearbox cross-mount?
Have you had to shift it rearward?
Look forward to updates
Posted: Mon Oct 01, 2018 6:04 pm
by 71GA
Thanks Tandanas, appreciate all the kind words.
As for the cross member i can't tell you, i don't actually have a 5 speed or cross member as of yet. I have read a few of the threads on here and lots of people have mentioned it as an issue so we will see. I'll keep you posted.
Cheers,
Marty
Posted: Fri Oct 05, 2018 10:25 am
by tandanus
The issue with the GAs is that their g/box cross member bolts inboard of the chassis rails.
The GBs bolt up through the rails.
So if you can find a GB cross member, you can drill through the rails, add crush tubes and bolt up
Welding to rails is forbidden where I'm from, so you cant just extend the GA inboard mounts rearward
Also you may have to move the gear-stick hole rearward a bit.
Just cut away from the back of the hole and weld it to the front
Some 5 speeds have shorter extension housings than others - short is good.
Others here have more experience than me in this, so I'm happy to be corrected on any of this.
Posted: Fri Oct 05, 2018 8:31 pm
by 71GA
Well i didn't know there was a difference from GA to GB, thanks for that it's certainly something to think about.
I was aware of the extension housing variations, from my understanding i need a GE GH Sigma or any lancer narrow block box.
2018-10-05_07-53-39 by
Some center caps for my wheels arrived in the mail this week, pretty happy with them.
Cheers,
Marty.
Posted: Tue Oct 16, 2018 1:11 am
by 71GA
Started to peel back the layers of rust in the chassis rail.
2018-10-15_11-06-28 by
As per usual i had to take out more metal/rust than planned.
2018-10-15_11-07-02 by
The two layers made things a little interesting
2018-10-15_11-07-50 by
20181015_183722 by
All in all it doesn't look too bad.
Cheers,
Marty.
Posted: Mon Oct 22, 2018 7:52 pm
by 71GA
Inner skin fabbed up.
2018-10-22_05-20-41 by
Then tacked in.
2018-10-22_05-15-13 by
2018-10-22_05-15-42 by
It will be fully welded and ground down before the outer skin goes on.
Cheers,
Marty.
Posted: Wed Oct 24, 2018 8:17 pm
by 71GA
Inner skin fully welded and ground down.
2018-10-24_08-39-49 by
2018-10-24_08-40-56 by
Cheers,
Marty.
Posted: Mon Jan 21, 2019 4:02 pm
by 71GA
Finished off the chassis rail over the weekend.
2019-01-21_04-14-18 by
This time i made the side curved piece first.
2019-01-21_04-14-51 by
Then welded to inner rail.
2019-01-21_04-15-15 by
Then attached the bottom piece and ground down.
2019-01-21_04-16-34 by
Happy with the results.
Cheers,
Marty.
Posted: Fri Jan 25, 2019 6:59 am
by Superscan811
Great work..
Posted: Fri Feb 15, 2019 7:38 pm
by 71GA
Thanks Superscan.
The engine bay is mostly stripped.
2019-02-15_07-58-00 by
Layed some etch primer down to protect the bare steal.
2019-02-15_07-58-20 by
Still needs a bit more prep but not too far of spraying some hi build primer.
Cheers,
Marty.
Posted: Sun Mar 10, 2019 6:59 am
Good to see you're still plugging away at this Marty.
Any updates since the last?
Dave
