who said it wouldnt work fit like it was made for it
1UZ Scorpion
Re: 1UZ Scorpion
factory 1uz manifolds perfect fit
cross member lined up perfect all need was an angle line peice to be welded
only issue brake booster 6 inch is needed i got one but i wanna use my factory master cyl so need to find 6-7" booster to fit my factory master
- amgis_obrut
Re: 1UZ Scorpion
modified datsun stanza booster works
Re: 1UZ Scorpion
What needs to be modified on the stanza booster
- amgis_obrut
Re: 1UZ Scorpion
needs to be opened up and have the mounting bolts changed for the sigma ones, its a bit of stuffing around but it works
edit just noticed scorp mc is different to sigma, so you might need to consider something else
Re: 1UZ Scorpion
love this conversion ,tight squeeze thou ,be very interested at how much power it makes at the treds ,
much better then dropping a commodore buick motor in .
hope to see it running next post ,
= Lancer 1976 =
Re: 1UZ Scorpion
We did the same conversion on a mercedes which weighed 1380kg
She made 170kw at the treads with an upgraded exhaust system and ran a constant quater mile of 13.9
The scorp weighs a tad under 1200 with that power could run a high 12 early mid 13 sec
