Picked this up off a mate who does it on his front engine dragster some may have seen it before
its an easy cheap way to secure hose/wires etc and also make things neater, it can also be used for ignition wires
you'll need a few quality cable ties and depending on what your doing you may just need to use normal ties or if you need to secure things to body/chassis etc you will need the push in ties
heres a demo of how i do it
I use this type when mounting to body/chassis, just need to drill a 6mm hole and push them in
First just loosely loop a tie around the thing you need to secure
next loop another tie around the first tie like this
pull the 1st tie until hoses are nearly touching the 2nd tie
pull 2nd tie tight and there you have it
Heres some i done on my car using the push in ties
Cheap easy way to secure cables/hoses
- amgis_obrut
Re: Cheap easy way to secure cables/hoses
That's a very clever idea Mick I will be using it
- DanTurboLancer
Great idea! and neat
Yep, a neat idea.
Only improvement I would suggest is to use self-adhesive cable tie mounts rather than the pug-in ones - so if you need to move things around in future the car doesn't end up looking like swiss cheese !
