Does anyone know of a method to get the front seats of a GE Sigma to go further back?
Our cars seat is just on the point of being too close to the steering wheel, and I am not a big fellow, with the adjustment in the last hole.
The only way that I can see of fixing this is to make a further square hole in the runner, but thought someone else might have had success with another method. If not,has anyone got a spare set of runners?
Sigma seats
Re: Sigma seats
i'm 6' 4" and i fit fine into my GE scorp, maybe find a set of scorpion rails?
- 81GL
Re: Sigma seats
Sounds like your already on to the easiest idea mate; re drill the holes in the rails.
If you find that this is still not enough? bolt some 30*5 plate on top of the rails and then you can put the holes where ever you want ;) (if you do go this route... weld the bolts to the plate, this will save mucking around with tightening a bolt in a small space, and it will save hight by having to use spacers to clear the bolt heads.) - Used to have a similar set up in the GD when i had different seats in there.
Nick.
Nick.
