another random question
out of interest
what should the oil pressure be in standard
2L astron from GH
mines over 80psi
thought was the gauge but tryed another
still over 80psi
few people think its a bit weird?
oil pressure
oil pressure
85GK GSR - EFI Camn
85AB GSR VR4dia- Build
Re: oil pressure
Will check tomorrow... when radiator is back in.
Re: oil pressure
yeah that up there
should be around 60psi
no need to be that high and going to cause you some oil leaks
did you rebuild the oil pump and change the spring or shimmed it
or try changing your oil filter and using the correct oil 10w/40w
cheers stealth
cheers stealth
Re: oil pressure
So I am guessing that you welded up the oil pressure relief valve. ;)
Re: oil pressure
dude your wasting hp make oil pressure
not good
are you putting 100psi into your turbo,and how are your seals
looking
cheers stealth
not good
looking
cheers stealth
- 81GL
Re: oil pressure
Lethal G wrote:my 2.6 makes just on 100psi if i lean on the long pedal
That is tyre smoke right
- EVL076
- S-G Veteran
Re: oil pressure
well i thought it was tyre smoke (that pic is of Green's Tuff.... different car to EVL ;) )
got a brand spanking new oil pump sitting here that is going on, after the respray, but before it leaves the shed
i flogged it hard once, and noticed the oil pressure was a tad high so it then got driven according to oil pressure
so i did look after it in that respect, all should be good
(turbo seals are brand new)
