efi carby
efi carby
ive recently bought a magna it is efi for the engine it's for my galant now what id like to do if its possible is take the motor out and and fuel pump and attach my twin weber's and manifold and run it off the factory fuel pump with a fuel regulator another thing is the tps could it be modded to run with the weber's
Re: efi carby
Mate I was thinking the same thing so I called re-carb or something similar and he told me that there are no manifolds for the magna head.
I'm not sure if he's right and I'm not sure how difficult it would be to make one or modify an Astron 1 manifold.
Re: efi carby
there is a multi-fit weber manifold for the asstron 1 and 2
Re: efi carby
? i may not be getting it but what would be the point of running an ecu and all that wiring, to end up with a carby engine ?, could you not just get an after market pump and reg and be straight forward
spoto a 57 chev
...a 57 2 door
...a 57 2 door
Re: efi carby
Isn't what your trying to do is basically single point or centre point injection????
Re: efi carby
rather then buy a new pump id prefer to use the magna efi pump
Re: efi carby
Lol! Forget about it, the pump your reffering too is 35+ psi opperating pressure, webers need no more than 5 max. Sounds like your idea is like trying to reinvent the wheel. Why not go with webers and a elwctronic dizzy out of a gn siggy?
Re: efi carby
ill let you know how i go mate
