hey guys just want to know what is a second hand side drapht manifold worth for a 4g32?
found one for 150... ??
sidedrapht manifold
sidedrapht manifold
Re: sidedrapht manifold
bit more specific would help but Ill assume twin webber style? Lynx or? but 150 is probably not bad if its not damaged... AND the Mits factory one wont work unless you get the factory soft mounts with it just in case you find a NOS factory one.
I got a factory sidedraught manifold, but very attched to it....
I expect he means Weber side-draught, not AISAN side-draught. I run AISANs on my GA, they are a good carb, but have nowhere near the flexibility of tuning options that DCOEs have (unless you want to get into adapting them to take SU parts ;) ). Depends what you want and how much $ you have. Setting up a pair of DCOEs for a 4G32 from scratch can be $$$ - mostly labour and dyno time.
T.
T.
John Ruskin
John Ruskin
the brand is '極東' hahaha
well has that stamped on it, the coolant hose link thing that bolts on is 4 screw, and says it fits 4g32's so i dunnoo...
Not like mine: "the coolant hose link thing that bolts on is 4 screw" -
how many different sorts can there be? :? Unless its off a belt drive....
T.
T.
John Ruskin
John Ruskin
nah hes looking at a "far eastern" twin sidedraft manifold , Its going to cost you $300 plus landed here, find one locally...... (has a 4 bolt thermostat housing, dunno why, not sure if a std housing will bolt to that?). they turn up on Ebay now and then , just be patient
yea cheers guys
Soft mounts dont last as they deteriate they leak air, you will
know when you hear cherping comming from the engine. Does
not really effect performance, you just drive around like you've
got birds under the bonnet.
1 X GC GALANT WAGON
1 X GC GALANT WAGON
3x la lancer 2door
2x gc galant hardtop
1x gc galant wagon
3x la lancer 2door
1x gc galant wagon
