Are galant sedan and coupe leafs compatable?
as title states, im wondering if GC sedan and coupe rear leafs compatable and if so are there any differences with spring strengths etc similar to the wagons?
vrooooom vrooooom!!
Re: Are galant sedan and coupe leafs compatable?
Howdy kenvv, I'd bet they are interchangeable. I did use GD wagon springs in an LB hatch and had no issues with bushes or swing shackle locations. I did however have to grind off the locating discs on the lancer diff to mount them up and also use all the related mounting hardware.
no worries, cheers mate. still going to head down to that place on port rd and ask them some questions sometime next week too. cant wait to stop riding bump stops
vrooooom vrooooom!!
I don't know about actual spring rates, but Galant sedans, Hardtops (coupes), Lancer Hatches and Lancer sedans all run 2 rear leaves. I can't see any reason why they would be a different weighted spring?
Well I now hear GB sedan rear leafs in my GC Coupe and it sits and rides really well
I found when I went to put wagon 5 leafs in the coupe they were wider than the 2 leafs that came out, and fouled on the shock mount. I later found a set of three leaf springs but can't for the life of me remember where
They do fit but they sat the car up too high and were too hard so I went back to the 2 leafs. The 5s would.have been waaay too high and stiff for me too.
I was told by a bloke who rallies a GB (he's not on the forum) that the best rear spring set up is get 2 sets of standard springs, pull them apart and make 1 3 leaf set.
My dad added half a leaf but think he turned the half leaf upside down and fitted for memory 2 inch lowering blocks.
When I did a motokhana on a wet skid pan a couple of months ago, the car would not axle tramp which I was quite impressed with. I can't remember for sure what shocks are in the rear but pritty sure they are De Carbons.
1976 Galant Hardtop
- Rallyant
- Contact:
4 and 2 door are the same.
I ran wagon springs with a couple of leafs removed and reset to the ride height i wanted (better side to side rigidity with the wide leafs) But like TJ said, the shocks will dont fit, So I just used the spring plate from the wagon so the shocks would fit (from memory)
I have also tried adding an extra half leaf and full leaf etc to the std pack. I like my 3 pack wagon set best. I also have a 4 pack custom set with reverse Eyes in one of my coupes, was done by pedders when the last owner had the car, this is also pretty good. the 2 pack is probably best for rally,(long travel softer setup) but not as good for rd performance. nice for rd comfort tho.
I did hear they had 3 leafs in the jap cars, the 2 packs were an Australian thing. Can anyone confirm that?
Dodge Colts are 3 not sure any Galants had more than 2 , GTO MR had 4 dunno about lesser GTO's. You need more than 2 for rally or youll be on your bump stops all night.
- 81GL
Rallyant wrote: I like my 3 pack wagon set best
Went and saw our local pedders shop here, they didn't want anything to do with altering leaves? guess it depends on the owner.Rallyant wrote:I also have a 4 pack custom set with reverse Eyes in one of my coupes, was done by pedders when the last owner had the car
When I was first looking at rear springs in the coupe I also went to my local Pedders to get them reset and they didn't want to do it as "they were old and likely to break in the machine"
If that's the truth then I can understand their hesitation, I mean I'd hate to think what sort of damage half a broken spring being fired across a busy workshop would do.
I'm pretty sure some places make new custom springs for trailers and utes and what not, I wonder if that's an avenue worth considering for those serious about setting up their rear end?
While I did go back to 2 leaf springs, they are a bit soft and with passengers in the back, It does bottom out a bit![embarrassed :$](./images/smilies/msn_embarrassed.gif)
If you can find a spring manufacturer in your area you can ask them if they can reset your leaf springs. Make enquiries here in Adelaide and the guys I spoke to were prepared to do it. Not enough to just put them in a press- they have to be re-tempered or they'll collapse back to their original height.
If I can find some wagon springs I will be taking them to be reset, I want the rear about 2 -2.5 inches lower and stiffer ![happy :)](./images/smilies/msn_happy.gif)
The spring will be straightened out a fair way to accomodate a 2.5" drop. Lowering blocks, new shackles and taking out the bump stops will give the same result and work out cheaper.
Not really a fan of lowing blocks, they will make the spring 'S' under load. Might have to do some spring measuring to find something else suitable ![Wink ;-)](./images/smilies/icon_e_wink.gif)
I think the diff splines will explode before you distort wagon springs! They made a dramatic difference in my LB but did jack the rear end up...
Nath76LA wrote:My dad added half a leaf but think he turned the half leaf upside down and fitted for memory 2 inch lowering blocks.
When I owned the hardtop, I shortened an additional sedan leaf (to give more rate in front of the axle than the behind) and added lowering blocks. These were either 1 1/2" or 2", I can't recall. The shocks are indeed deCarbon monotube which I found brand new on EBay a few years ago.
I found this setup worked quite well for a low budget.
In case you were unaware, deCarbon originally developed the monotube gas shock absorber ("damper", more correctly) in 1953.
http://en.wikipedia.org/wiki/De_Carbon
Bilstein, KYB etc bought the licencing rights off deCarbon.
I am now enjoying a 1986 Porsche 944......
Roger
Maybe the colt sedans have 3, but my coupe definitely only has 2 leafs just like you guys.Torana68 wrote:I did hear they had 3 leafs in the jap cars, the 2 packs were an Australian thing. Can anyone confirm that?
Tim
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
88 Fiji Blue Starion
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
yep 3... the leafs are not the same thickness as here either, are your coupes imported or assembled there? (I forget whos car this is )
![Image](http://i83.photobucket.com/albums/j291/torana68/22014490019_large.jpg)
All our cars were imported, none assembled in the US. Got right up under my car earlier today before i posted, don't have that bottom leaf on mine.
Tim
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
All our hardtops were imported, sedans and wagons were assembled here, not sure if the panels were stamped here or not?
panels suppiled in "kits" from Mits.
