GB maunual
fridgeGB
GB maunual
Post by fridgeGB »
Hey fellow G-Lanters lol just put a post up in SUSPENSION/BRAKES/WHEELS asking about wheel bearings for a GB. Thought id ask in here if anyone has a GB manual that would be able to give me a part number. Thanks for the help :)
2Lgalant
Re: GB maunual
Post by 2Lgalant »
Are they the same as ga if so I can get it for u ive got a ga book at home
fridgeGB
Re: GB maunual
Post by fridgeGB »
as far as i know yes they are the same. That would be unreal if u could cheers :)
2Lgalant
Re: GB maunual
Post by 2Lgalant »
I'll have a look in the book now let you know in 10 mins or so
Re: GB maunual
Times up, lol
fridgeGB
Re: GB maunual
Post by fridgeGB »
HAHA
2Lgalant
Re: GB maunual
Post by 2Lgalant »
Well I can't find a part number just dimensions
fridgeGB
Re: GB maunual
Post by fridgeGB »
Yer sweet. Doest it have a pic with dimensions or just dimensions. It has both I'll grab the details off u and I'll still grab the dimensions even if there is no pic. I found out off Mitsubishi Australia that they don't make it anymore so I'll have to try and find the right size spacer to make it work. Does it say in the book if there's a spacer or just the bearing dimensions?? Cheers for your help again man. Atleast if u ever have to change yours we will know wat to do straight away lol :)
Torana68
Re: GB maunual
Post by Torana68 »
what spacer?
fridgeGB
Re: GB maunual
Post by fridgeGB »
Torana68 wrote:what spacer?The original one i pulled out a year ago had either a seperate spacer or a one piece bearing/spacer. I wish i kept the bloody thing lol
Torana68
Re: GB maunual
Post by Torana68 »
ok, there are no spacers in rear wheel bearings, there is a bearing and the retainer, there are 2 bearing sizes and the bigger one wont go in a small housing, you might (????) be able to put a small one in a big housing but it wouldnt work for long :) If something is knocking check (by removing and inspecting!) the spring bushes , front and back, also pull the axles and check the fit of the bearing to housing someone may have damared something at some time.
Torana68
Re: GB maunual
Post by Torana68 »
fixed is it?
