boss kits
Re: boss kits
Same boss kit as the Sigma, Galant, Lancer, Starion and so on. Just make sure you get one with the correct stud pattern as there are a couple of different ones. Obviously a Momo one will work, but the Autotechnica does too as they are a multistud pattern. I'm not sure about the Saas one.
Autotechnica part # 900
Saas part # 1BK90L
Momo part # 6101
Saas part # 1BK90L
Momo part # 6101
Re: boss kits
There are two standard wheel patterns, autotecknika has both in the boss kit. The issue is more the indicator cancelation. In the galant and lancers they use two roll pins. as for the sigmas and scorpians I am not sure. For my galant I ended up with a Colt one from memory as this would except the correct roll pins and sit at the right place on the steering shaft, the sigma one was not correct. Considering that the car is a very close cousin of the sigma I would expect the sigma one would be the one for you. A reputable parts supplier should have what you need and/or be able to show you the differences between the boss kits.
Good luck.!
Good luck.!
Re: boss kits
The momo boss kits are also collaspible making them legal aswell....
