Hi guys
Does anyone have a picture of the bottom side of the Celeste (LB/LC Lancer hatchback) body, just above the differential? I have there 2 bolt holes but there is nothing mounted. And I have the rubber damper installed about 20 cm's forward of it... Should there be a 2nd damper on that location?
Thanx!
Sven
wanted: picture of bottom side body
- BlueThunder
- Rally_2.6LC
Re: wanted: picture of bottom side body
I just had a look under mine. I cannot see the two extra bolt holes you describe.
I have the rubber stopper just above the diff, but no other bolt holes. There is a single hole that goes through the floor, where the wiring for the fuel gauge go through but that is it.
Matt
Matt
- BlueThunder
Thanks! Strange, as far as i can tell they are there from factory... I'll try to take a picture of them next week...
Greetz
Sven
Greetz
Sven
I have a couple pics, but they aren't the best.
