anybody got any idea if and where i can get my hands on some coilovers to fit my LB sedan, and maybe some longer lower control arms for a bit of extra camber..?
cheers..
coilovers
Re: coilovers
Khrony,
I have coilovers on my LB rally car. They are MCA/ Proflex built by Murray Coote. He recently built a number of sets for some replica African Safari cars. Pretty expensive but absolutely amazing and worth every cent.
Dan
Dan
2 x LA 2 Dr
3 x LA 4 Dr
1 x LB 4 Dr
2 x 4G32 Twin Cams
3 x LA 4 Dr
1 x LB 4 Dr
2 x 4G32 Twin Cams
Re: coilovers
You can buy coilover sleeve kits very cheap, just get someone to remove your stock spring landing and weld in the coil over kit. Have a dig through eBay and find the correct diameter for your struts. You may need to change ya stock struts for GH struts.
http://cgi.ebay.com.au/88-00-Honda-Civi ... 8810662874
Thats what I have on my Galant Hardtop
![Image](http://i234.photobucket.com/albums/ee271/Galant_GTO/Coilovers.jpg)
Re: coilovers
i think i might go wiv a set of these.. if thay will hav sum to suit my galant strutt? wat pound springs are you running?
Re: coilovers
if you want sum camber its probly ezeyr to get adjustable stutt tops..! autosport is were i got myn from....krohny wrote:anybody got any idea if and where i can get my hands on some coilovers to fit my LB sedan, and maybe some longer lower control arms for a bit of extra camber..?
cheers..
Re: coilovers
Yeah, adjustable tops are the go. Mine are running 260lb, after speaking to Cheater he thinks this should be spot on for hard road and a bit of track work. Here is a pic with the part number
KPS042
![Image](http://i234.photobucket.com/albums/ee271/Galant_GTO/newsprings.jpg)
Re: coilovers
What shocks are you running in your coilovers?
I put Sigma ones in mine and they fail to capture.
Rob
Rob
4dr LA Lancer
CBR600rr 07
CBR600rr 07
- Rally_2.6LC
Re: coilovers
Hey Galant_GTO, the link you posted are for honda coil overs, was this just a generic link or will these ones suit GH scorpion struts???
Also if u bought one of these kits do they come with springs or do u have to buy those separatly like the king spring ones you have?
Cheers Matt
Cheers Matt
Re: coilovers
Rally_2.6LC, that was just a generic link, as different models have different diameter struts I figured it would give people an idea on price. If you measre the OD of your struts he might even have something that will fit. I bought mine already converted with no springs, thats why I have kings but the kits I linked do come with springs I think, but as they will be for a different car they will more than likely be too soft or the wrong length.
r20bear, I am running Monroe Sensortrack to suit VB-VP Commodore, they are stiffer than stock and a little shorter allowing you to lower it without bottoming out the insert.
