as there would be a DIFFERANCE in hp /torque as your not trying to accelerate
the pump ,receipracting parts and weight accleration make a huge differance
cheers stealth
![nerd 8-)](./images/smilies/msn_nerd.gif)
you will also need the chain tensioner Ill take some pics today/tonight IF i can get my camera working! to show what it looks like,rob440 wrote:ok, so I need the pump, sprocket and the chain ( seals and gaskets of course )
will u post to Qld?
rob
I would be surprised if there was no increase in HP from changing the pump.Torana68 wrote: no HP increase from an oil pump change, some from removing the ballance shafts. They are after high RPM reliability, a std engine wont go there.....
Rally_2.6LC wrote:It would be a great group buy (might get the cost down a little, as pump alone is $251, then gasket and shaft). And there is at least a 15-20hp gain (according to Ron Masing from Coltspeed, as well as some of my friends who have done this to their rally cars).
Cheers Matt
I must say I agree - 10 % of this claim is prob closer to the markTorana68 wrote: I think 20 HP from an oil pump is a ridiculous claim, Ive heard high figures for the shaft removal and consider it dubious, wheres the dyno sheets? never trust word of mouth...
Posts like that is what makes this place stink, not quoting HP numbers. As far as i can see people have made it pretty clear they have only heard these hp #s from other people and given there sources, And not done a back to back dyno them self, and then spoken about the possible reasons for this been or not been tru.Torana68 wrote:... Ill go 2HP difference with the pump which probably isnt measureable, Ill go 5 on the ballance shaft removal ,BUT it needs to be dyno'd or it didnt happen, the number of people who spruke HP figures but havent even seen a dyno is amazing. The number on here who have had a car on a dyno that they built the engine in is probbaly 3 and Im one of them. DONT quote HP figures unless you have a dyno sheet you can post to back it up, just makes the whole place smell when that starts happening....
and Ill add asking someone to chuck one in and dyno it shows a lack of knowledge in the time and cost involved, you are probably expecting the guy to spend $2k of his own money and time to test a part when a change of gearing (sprocket ) would do but anyways hes not having any problems with his current set up? put your hand in your own pocket! WONT HAPPEN!
"cant prove it dont say it" You have been stating that changing to a forklift pump will not give a power increase with NO dyno proof.Torana68 wrote: tuff , I get tired of the whole my car does 10's but woops I cant prove it and the it'll add 20 HP thing without proof , cant prove it dont say it, for now Ill just say what I think.
because of my big smile at the end of the sentienceTorana68 wrote: and I was supposed to know that how???
Code: Select all
there is some debate as to how much power the twin balance shafts cost the engine. The basic figure given is usually around 15 hp (11 kW), but this may be excessive for pure friction losses. It is possible that this is a miscalculation derived from the common use of an inertial dynamometer, which calculates power from angular acceleration rather than actual measurement of steady state torque. The 15 hp (11 kW), then, includes both the actual frictional loss as well as the increase in angular inertia of the rapidly rotating shafts, which would not be a factor at steady speed. Nevertheless, some owners modify their engines by removing the balance shafts, both to reclaim some of this power and to reduce complexity and potential areas of breakage for high performance and racing use, as it is commonly (but falsely) believed that the smoothness provided by the balance shafts can be attained after their removal by careful balancing of the reciprocating components of the engine.
according to my calculations thats probably about rightlpgalant wrote:itll probably give 1.2418954 of a hp at flywheel, lol
crap... gotta agree. Im thinking maybe these dodgy figures came from someone who dyno'd their old engine then after bebuild with shafts gone ( some people used to do this, dyno the car on arrival and after, not a bad thing), obviously if the owner paid for a freshen AND shaft removal its gunna have easy 10-20 hp more than the tired engine that came in.. maybe. So off he goes to the "Forum" claiming a 20 HP increase for the shaft removal and off go the spankers telling everyone....stealth wrote:surprize surprize noones answering lp's question
rallant you guys are CLAIMING that a forklift pump is high volume
let thay flow less than other pumps
to work it out on a built engine you need a spintron(reverse dyno)that spin engine
without it starting and tells you hp/torque required to turn engine at given rpm
build an engine bring it in and ill spin it for you it only costs about $300 an hour
to run!
nah (well you could.. ) as previous post you can do it on a std dyno, BUT that will involve using an engine as supplied, dyno it, then a prartial strip to pull the shafts etc, another dyno, partial strip different pump and back on the dyno probably 2k worth if its your mate, its doable on a sunday if anyone wants to spend the time and money but as RALLYANT has found
"if the flow of the sigma was the same then it would only chew about 1.9 hp) (74gpm) the 80psi of the magna pump would take that to 2.5hp plus the 1/3 wider gears would put that over 3hp
But thats still no where near 20hp claimed by Ron!!!
as I said before the guy wants your money, you can tell from the price for the "RACE" (?) pump hes full of it , there I spat it out, Ive delt with him before but never bought anything for good reason. Beware the sprukers who are selling stuff unless they can proudly show off a dyno sheet (which still can be an issue but its a better guide) or have proven track times.
on a stock astron theres 7hp for removal of shafts and i dont use the low volume
pumps as there more costy and id rather pay for parts that make a difference in a
positve direction
cheers stealth
I have only driven my car about twice since i put the pump in, having some clearance issues with the dump in the coupe, was fine in the sedan with no brake booster. but like you the old car got put aside and is awaiting some loveMrBishi wrote:So have any of you that have used the forklift pump encountered oil drainback on cold startup?
I have NEVER claimed that the forklift pump was a hi flow pump, If you actually read my posts you would see i have been claiming that the potential problem with the sigma/magna pumps is that they may very well flow too much at hi RPM. And therefore wast power, and cavitate at hi rpmstealth wrote:surprize surprize noones answering lp's question
cheers stealth
Last I spoke to them they ran a cast iron oil pump of some kind, i think the same as std pump.Torana68 wrote:and if the next question is "who would you go to then?" Id be doing it myself if I felt the need for an ANCHORTRON, which I dontbut the guys at RPW in perth have a good knowledge of the Anchor..
this is a NA engine in a Galant coupe:
12.920 @ 103 mph at Quit Motorplex 13/01/01 running Version 7 Motor with street extractors and gear changes at 8000 rpm!
23/11/01 - Version 8 motor dyno'd at 180hp @ 7000 rpm rear wheels with overloaded ignition system and no muffler.
I saw the time slips I saw the car. Contact them as I dont think they changed the oil pump but they have expereience in high RPM egines and real development, not an add its what I have seen them do.
Dave use to sell a cast iron H/V pump from memory - in the early days of running the sigmaTorana68 wrote: 23/11/01 - Version 8 motor dyno'd at 180hp @ 7000 rpm rear wheels with overloaded ignition system and no muffler.
I saw the time slips I saw the car. Contact them as (I dont think they changed the oil pump ) but they have expereience in high RPM egines and real development, not an add its what I have seen them do.
This makes scene to me, And if they were flowing too much, they could end up sucking dry a lot sooner than a fork pump. Still need to find out the flow rates to work all that our for sure tho.Mitsiman wrote:
We have never had a problem with cavitation on our engines, but we learn't early on that the problem was not so much the pump pick, but the lack or oil being returned back to the sump pan. The main issue with the astron engine , is that too much oil sits on the top of the cylinder head and takes too long to get back down to the sump pan at high rpm, which people mistakenly put down to cavitation. The oil pump was cavitating, but only because of oil starvation, not rpm
yep its been lonely on here ROFLAO................ lots of people with knowledge just need to get people to listen, and learn how to spot bullsh&*, now that the pump issue is sorted (no ones really going to buy the "other" pump now are they?) everyones chucking the ballance shafts, yes? good ,now about those wonderfull inline fuel converters and an electric turbo off ebay and Ill have at least an extre 200 hp for nearly nothing.....stealth wrote:hi mitsiman
good to see people with knowledge turning up here
cheers stealth
