HELP
HELP
Could someone kindly help me locate an M9 head for my 2.6 engine. salvage yard, web page, etc?
I have spent many hours searching but I'm not having any luck. Here in the USA, we have a web page www.car-part.com is there anything like that in Australia?
Re: HELP
You guys didn't get the Astron II afaik, so you may have to import one
Re: HELP
There is another option available, if you are allowed to use different pistons.
A 1981-82 Celica 22R piston or a Holden 202 piston.
![Image](http://users.tpg.com.au/backman/SG/PARTS/PISTON.jpg)
Cheater has machined the 202 piston to fit the dome of an early astron head (piston on the right).
The piston on the left is a Wiseco forged 22R Celica. it has a 3mm more compression height than a standard astron piston, and a 24.7cc dome.
you would either need to use a 2.5mm de-compression plate or machine the edges of the pistons (like cheater has done to the Holden piston) to match the dome of the head.
It would give you a CR of around 16:1 using an M6 or M7 Magna head.
If you were going to use the standard cast celica piston, they don't have a dome, they have a circular raised section, which could be easily machined off when machining the edge.
This would give you more options on a lower compression ratio engine.
![Image](http://i3.ebayimg.com/01/i/001/01/46/ccac_1.JPG)
The pistons on eBay
The cast pistons aren't ideal for racing as you would know but it would be a good place to start your design.
The pistons on eBay
Re: HELP
Aren't they the pistons you get if you're doing a 2.4 de-stroker?
Re: HELP
well, I got the toyota pistons mocked up. I marked where I need valve reliefs and my friend is going to spot face the pistons. I also milled the head 0.120" (3mm). Should around 13:1. I hope this will get me the power I need to compete against those pesky Dodge Neon's
Re: HELP
Hello, I need to revisit this topic.
I was sizing up the toyota pistons. I don't see any way to make it work. by the time I machine down the piston above the ring to clear the head, I have .100" between the top of the piston and ring. that's way to short a distance. Going that low will cause ring failure.
So back to my first question, can anyone help me locate an M9 head?
cheers.
cheers.
