What material are Fuel Injectors made of?
Just trying to find out what normal fuel injector internals are made from.
Steel or Stainless steel?
The reason is because I am water injecting the engines I'm building and I would like to properly control the water flow.
I already have the pumps and the standard water injection nozels but it's not an exact method.
I was hoping that there are some Stainless Steel injectors I can use. They would only need to be about 100cc.
cheaterparts
Re: What material are Fuel Injectors made of?
Post by cheaterparts »
Superscan811 wrote:Just trying to find out what normal fuel injector internals are made from.
scott
my guess is that they would use steel - reason the injector valve is opened with an electric
pulse - magnetic and stainless dont mix
by the way I found the bmw youtube
http://www.youtube.com/watch?v=61G8uQr18Qc
I wont my JPS to sound and go just like that
wheelnut
Post by wheelnut »
IVE USED 3SFE CAMRY COLD START INJECTORS AS WATER INJECTORS NO PROBLEMS.DONT KNOW FLOW RATES FOR THEM BUT I JUST ADJUSTED THE PUMP PRESSURE.
gb galant efi 2.6 track toy
gj sedan hack car
