Engine won't run
Posted: Sun Feb 19, 2017 5:45 pm
by L200expressL200
I pulled my 4g63 8v out of my l200 for new welsh plugs,water pump etc and now I'm having trouble with it.
It will crank and crank but not run. I double checked the timing belt. I have spark but seem to be having a fuel problem. I've replaced the fuel filter and mechanical pump but have no fuel. I can see the cam turning the fuel pump rod but have no fuel flowing.
Any opinions?
Re: Engine won't run
Posted: Mon Feb 20, 2017 8:11 pm
by Scorpma82
U put the carry back on didn't ya??? Lol Nah seriously, check this g's like fuel pump (for pressure), make sure floats and other carry settings are correct also
Posted: Wed Feb 22, 2017 9:01 pm
by yno26galant
just put a electric pump on it and check if it starts
Posted: Fri Feb 24, 2017 4:45 pm
by L200expressL200
Got the fuel side sorted but still no luck. Got spark,fuel and triple checked the timing.
Posted: Sat Feb 25, 2017 11:56 pm
by Superscan811
Where are you?
There may be members close to you and able to help.
If you have spark and fuel, it should at least fire (or back fire).
Posted: Sun Feb 26, 2017 3:26 am
by L200expressL200
Canberra, inner south of the city.
Yeah got me beat!
Posted: Sun Feb 26, 2017 12:06 pm
by Superscan811
To confirm you have spark:
1: Remove Sparkplug 1
2: Remove and label the other leads so the engine can't start.
3: With the ignition off, turn the engine over by hand until No:1 cylinder is on the compression stroke ( seal your finger over the sparkplug hole and feel when there is a lot of pressure).
4: At approx 10° Before Top Dead Centre on the compression stroke, stop.
5: Loosen the dizzy and turn on the ignition.
6: Attach sparkplug 1 to its' lead and earth the metal part of the sparkplug.
7: While turning the dizzy back and forward you should get a spark.
If you get a spark all is good.
Re-install the sparkplug and leads.
This is also a way you can roughly set your timing without a timing light. Just stop turning the dizzy as soon as you see the spark, then tighten it up.
After confirming you have spark, to confirm you have fuel:
1: Remove the air filter and pour a tablespoon of fuel down the throat of the carby.
2: Turn over the engine and see if it starts.
It should fire (or at least backfire).
Sorry if I have over-simplified the process, but you never know who else may use this as a guide.
Posted: Sat Mar 04, 2017 9:57 am
by L200expressL200
I'm not getting a spark while doing step 6 and 7 but i have spark at the plug when cranking the engine.
Posted: Sat Mar 04, 2017 10:52 am
by Superscan811
L200expressL200 wrote:I'm not getting a spark while doing step 6 and 7 but i have spark at the plug when cranking the engine.
Most likely the timing is out.
First of all, recheck that No:1 cylinder is on the compression stroke. (with the ignition off of course)
Only turn the engine clockwise so there is tension on the timing chain. if you go past the 10° BTDC, don't just turn it back to the mark, turn the engine back half a turn then try again.
Next, note where No:1 sparkplug lead attaches to the dizzy cap.
Remove the dizzy cap and see if the rotor button is facing towards the No: 1 lead.
Fix and Re-check spark timing.
Posted: Sun Mar 05, 2017 8:46 pm
by L200expressL200
Thanks for the help.
It ended up being an oil pressure issue.
I hadn't primed the new oil filter so once I did that it fired and ran!
