timing
Re: timing
I have a weber on my 4G54 and I have my ignition timing set at 36° total advance measured at 3000 rpm
Re: timing
i dunno about final advance but i always set my initial advance to 10-12...
i had a rwd 626 that had weber, cams, exhaust, crane cams ignition and a valvesaver kit, it loved 16
Re: timing
Reconditioned and changed the mechanical advance of a GK scorpion dizzy this weekend.
Decided to play with the timing curve to see if there's more torque to be found in the Astron, in a fairly standard configuration.
I Nickel plated most parts to help recover from their worn state, but apart from a good clean, they were functional.
If you have one of these dizzy's, it's very easy to change the timing curve.
The standard dizzy has the pin on the other red slot (on the right hand side), giving around 25-degrees of total advance (including the initial 7-degrees).
The opposite slot gives an extra 5 degrees of timing advance
BUT
it is too skinny for the pin, so I "modified" it to fit.
Also, the spring tension is controlled by a cam (circled in green), which also allows you to change the timing curve.
The spring on the left is for the low speed advance and the spring on the right is for the high speed advance.
With a bit of trial and error, I believe there will be a decent gain.
BUT
