Hey just a quick one,
I heard that 4g33 and 4g32 cranks are the same, but 33's are nitrited..
Does this mean i can use my 33 crank in my 32??
4g32 4g33 same?
4g32 4g33 same?
Re: 4g32 4g33 same?
some 4G3 cranks are nitrided, for example the GS cranks..... others dunno.... wont make any extra HP, wears better and is suited to race use, in short unless you are racing it its not worth worrying about (and even racing at the level most would with a 4G3 it isnt worth worrying about). If its ground the nitriding is probably gone anyway..... should go in no problems if you want to .
Re: 4g32 4g33 same?
Re: 4g32 4g33 same?
According to the factory Engine Service Manual for the 4G32/4G33 ...
The crankshaft for the 4G32 engine has been taftrided*. The taftrided surface of the crankshaft is gray. The crankshaft for the 4G33 engine has an embossed mark "31" on No. 1 arm.
Sounds like your informant has his info the wrong way around .....
* Note : I assume they actually mean "tuftrided", which is the same as "nitrided".
Re: 4g32 4g33 same?
I'm 99 percent sure it's the 33 that had the nitrited shaft.
Re: 4g32 4g33 same?
Based on .... ?I'm 99 percent sure it's the 33 that had the nitrited shaft.
Re: 4g32 4g33 same?
Based on .... ?
Net forums
Net forums
Re: 4g32 4g33 same?
Based on advertised nitrited cranks for sale over seas. And an ex Mitsubishi works rally driver is the one that initially told me. Doesn't matter anyway I'm gonna just use the 32 crank.
