4g54 gearboxes
4g54 gearboxes
hay there just wanting to know what the gearbox is in a l200 petrol 2.6l 4x4 is it a narrow or wide?
Re: 4g54 gearboxes
so if its a wide block bell housing can i bolt a narrow bellhousing on?
Re: 4g54 gearboxes
As far as I know all l200 4x4s were 2lt ,the early ones 4sp and later ones 5sp,Then they went to 2.6lt wide blocks in the tritons
Simon
Simon
Re: 4g54 gearboxes
You can't bolt a narrow block bell housing to a wide block. Or vise versa.
Also, the l200s also came out with a 2.0 sohc 4g63![happy :)](./images/smilies/msn_happy.gif)
Re: 4g54 gearboxes
its a 2.6l l200 4x4 thats what they called in nz anyway, from what i have found out the gearbox in it will be a wide bellhousing can i swap the bellhousings over to a narrow one?
Re: 4g54 gearboxes
ok dam i guess i will have to find a narrow block l200 4x4 gearbox and swap that over
Re: 4g54 gearboxes
If your gearbox is wide, so will your engine. And only a wide block box will go on it.
Re: 4g54 gearboxes
yes i know that but im not putting a wide block engine in im putting a 4g63t dohc into a 4x4 l200 for a bit of 4wd mud fun
Re: 4g54 gearboxes
Hi You could use a starion block,its a wide block 4g63 then fit your dohc head etc to it
Simon
Simon
Re: 4g54 gearboxes
cheers simon might have to do that
Re: 4g54 gearboxes
Oh yea? Cool! So you need to keep the transfer case then? Or are you going rwd like a baja truck? The only thing you gotta watch is that the engine you're using never came out in a 4wd before. So it mightn't like the angles and load it will get.
Eg, a hilux often gets a v6 commode engine put into it for power. But what nobody realises is that it's for a 2wd road car, so things like the oil pickup aren't positioned correctly for off road use. My dad has done this and we've learnt the hard way. With the v6 hilux setup in particular. You put it up a steep hill and the oil pickup ends up out of the oil. The engine then can't get any oil, then bang! Your stuck.. We went through 3 engines and 5 gearboxes before we realised what was happening.
So just be careful with this conversion as it may not work like it should![happy :)](./images/smilies/msn_happy.gif)
