Which flex plate?
Which flex plate?
Hi guys I am thinking of doing an engine swap from 4g32 to 4g54 with the efi setup and was wondering what flex plate I will need if sticking with the g32 auto box? Will be doing a manual conversion once I have my full lisence. Thanks!
Re: Which flex plate?
You will need a flex plate from a narrow Astron.
Not sure if the Saturn torque converter will blot up to the Astron plate though. You may need to run a Sigma box?
Hmm if I'm going to change box I may aswell make it manual now.. Saves time and headache later
jap 5 speeds are impossible to find here in vic..
Strongest narrow block box you will find is a 5 speed from a Triton. Grab the flywheel and clutch while you are at it if you can.
Doesn't matter as long as it has a narrow block engine. 4G52/4 or 4G63
