4g54, 4g32 gearbox conversion
im looking at putting a auto 4g54 into manual 4g32 gen 3 galant.
but i want to use the manual gearbox and clutch from the 4g32 with the 4g54 engine, is this possible? or will i need to get a new gear box/ clutch?
also is there anything else you think i should know about this conversion?
Re: 4g54, 4g32 gearbox conversion
hey mate yea you should be fine with that hey, im not sure if the same box is used with the 4g32 as is with the 54 but i know that that model did come out with the 31, 32, 53 and 54 so i would assume it will all fit
this is of course as long as you have the stock narrow block 4g54, if its the wide block i think you will need a different box
i have a 75 GD galant and if i know if i was to put in a 4g54 i would have to get a jap box (5 spd) because the shear torque of a 2.6l compared to me 1.6 would shread the stock 4 spd if thrashed.
i know if i was puttin a bigger engine in i would deffo try and get a 5 speed tho.
there is a bit of discussion in this topic
http://sigma-galant.com/viewtopic.php?f ... d7e9da9c44
Code: Select all
http://sigma-galant.com/viewtopic.php?f=25&t=57&sid=a891ed9b489f69adcbbff8d7e9da9c44
how would i know if i had the wide block?
- EVL076
- S-G Veteran
fox wrote:how would i know if i had the wide block?
there are a couple of ways...
prob easiest is check the sandwich plate on the back of the engine. If this covers up the welch plug thats at the back, then its wide, if you can feel the plug, its narrow.
if the 2.6 is a factory 5spd, then its wide.
and you can measure the distance between the gearbox locating dowels on the engine block, i think the wide measures 330mm and the narrow measures 310mm, but if thats wrong measurements, someone will correct me
I cant agree there buddy. I ran a 2.6 Turbo, with Nitrous, thru a galant 4spd, and the only problem i had with it, was it didnt have enough legs, it maxxed out @ 171k's (well it would have went a bit faster, but 7500 was as far as i was willing to push the stock 2.6 anyways)shuggy wrote:i have a 75 GD galant and if i know if i was to put in a 4g54 i would have to get a jap box (5 spd) because the shear torque of a 2.6l compared to me 1.6 would shread the stock 4 spd if thrashed.
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
![Image](http://i11.photobucket.com/albums/a153/Turbo2Ltr/NRE-SPW2.jpg)
![Image](http://i218.photobucket.com/albums/cc254/lethal-galant/Shaw_mydesign.jpg)
![Image](http://i11.photobucket.com/albums/a153/Turbo2Ltr/gotboost.jpg)
![Image](http://i11.photobucket.com/albums/a153/Turbo2Ltr/gotnos.jpg)
yea i could feel the welch plug on the 4g54, well half of it.
also the 4g32 has a 5 speed box
- EVL076
- S-G Veteran
fox wrote:yea i could feel the welch plug on the 4g54, well half of it.
well it should bolt up then
the 5spd would be from a 2ltr (fine to use behind the 2.6) and will have 2 holes in the top where the box bolts to the engine (like 10/15mm apart, cos the astron uses one and the saturn uses the other 1)
ah i've just realised i've made a mistake
i have a 4g52, no a 4g54
make any diffrence to my original question?
its just the displacement A?
also it has a fat solex carb
im guessing its not standard?
![Embarrassed :oops:](./images/smilies/icon_redface.gif)
still fits up the same but now theres no chance of it being a wide block
gb galant efi 2.6 track toy
gj sedan hack car
gj sedan hack car
if its an auto 4g5x its narrow block and your g/box will bolt up
cheers stealth![nerd 8-)](./images/smilies/msn_nerd.gif)
cheers stealth
im apologizing in advance for thread high jack
i also need to install a 5 speed, but its going behind a 4g32 in a galant (need a new clutch so the 4 speed can go with it), i have 2 questions for now; will i need to any holes to fit it?, and will i need a cross member from a different car?
3x la lancer 2door
2x gc galant hardtop
1x gc galant wagon
3x la lancer 2door
1x gc galant wagon
- 81GL
Depending on where the gear box comes from... lol, you may need to lengthen the shifter hole.boyracer wrote:will i need to any holes to fit it?, and will i need a cross member from a different car?
Cross member, you'll have to modify, do a search for a thread by GB_BB4C on the old site with the way he did it, pretty good idea!
FOX - You will need a manual flywheel to suit the 2lt you have. The Saturns use a 5 bolt flywheel, Astrons use a 6 Bolt.
Nick.
thanks yea i can see that now as my engines are both on the floor in my garage.81GL wrote:FOX - You will need a manual flywheel to suit the 2lt you have. The Saturns use a 5 bolt flywheel, Astrons use a 6 Bolt.
will i have to find a 4g52 flywheel or any astron flywheel fit?
![Image](http://images.trademe.co.nz/photoserver/21/62555421_full.jpg)
there is a 4d56 flywheel im eyeing up on trademe ^^^
will the saturn clutch fit or will i need a new one of those too?
Ill make a thread of my build once i get a little more done.
Fox.
any NARROW BLOCK astron flywheel should do the trick for you
how much will that cost you as it might be cheaper for you to
to get someone over here to buy one and send it for you.
And yes your clutch plate should work ,ok but you need the astron
pressure plate.
pressure plate.
cheers stealth
hi guys
i have a question
can we install 4speed manual 4g32 gearbox to 4g54?
i have a question
