Flywheel?
Flywheel?
Hey everyone im in search of a flywheel from a 2L astron i have rung pretty much every sydney wrecker and am having no luck if any1 knows where i could get 1 or an aftermarket 1 or if any other model cars have 1 that will do the job with no modifications thnx guys
Drive It Like You Stole It
Re: Flywheel?
How bad is this hairline crack n how much u want for it?TUFSIG wrote:i have one sitting here however its got a slight hairline crack in it so i dont know if you would want that lol
txt me (number removed) or call wateva i dnt care thnx dude names adam btw
Re: Flywheel?
I may have one out in the shed if its there you can have it but I am in melb though . I wont use cast flywheels in my engines anyway ,for what I wont they are to heavy and I wouldn't dream of putting anything on my crank with a crack in it.SpEc_OpS wrote:Hey everyone im in search of a flywheel from a 2L astron i have rung pretty much every sydney wrecker and am having no luck if any1 knows where i could get 1 or an aftermarket 1 or if any other model cars have 1 that will do the job with no modifications thnx guys
I even dont wont to use a clutch with a cast presure plate - not after exploding one at sandown
Re: Flywheel?
get a 2.6 magna one and get a machine shop to bore out centre hole to suit the sigma spiggot.
gb galant efi 2.6 track toy
gj sedan hack car
gj sedan hack car
Re: Flywheel?
Will it be as strong as a normal 1 wats pros cons of doing this eg is it lighter or anything?wheelnut wrote:get a 2.6 magna one and get a machine shop to bore out centre hole to suit the sigma spiggot.
Re: Flywheel?
It will be a lot stronger than a cracked one.
Re: Flywheel?
Well i was planning on welding the shit outta it then getting it machined but have since found 1 from cheaterparts without ring gear tho magna 1 should fit straight up tho shouldnt it?C_Fernance wrote:It will be a lot stronger than a cracked one.
Re: Flywheel?
I believe the ring gear is the same. A lot of people run Magna starter motors in a Sigma and vice-versa.
Re: Flywheel?
......welding a flywheel would be a big no no.....
- karl_2ltgc
Re: Flywheel?
Yea i run a magna starter. Reduction drive means faster cranking and easier starting. Plus there all about 10 years newer and plenty in wrecking yards.C_Fernance wrote:I believe the ring gear is the same. A lot of people run Magna starter motors in a Sigma and vice-versa.
Re: Flywheel?
Interesting cos my car has trubl starting sometimes are they a straight bolt in swap i mite get 1 if they are. How much did u pay for yours karl?
- karl_2ltgc
Re: Flywheel?
Straight bolt in.
I just picked mine up at the wreckers, probably $30 or so. Heaps of magnas just try to find one that looks like a reco.
Re: Flywheel?
Reduction starter is the way to go. Spins the crank faster, & easier on the battery. Brand new costs $120~$160, or much less S/H, typically $50~$100. Also S/H ones will be much newer the stock S/H starters.
Re: Flywheel?
Cheers guys might do that when i was ordering parts from auto1 the other day i had a look in the book and apparantly my car supposed to have a battery with 600CCA (cold cranking amps)
thats nuts i think. Any1 have an idea wat size battery the magna has? when i bought the car it only had a 520CCA battery in it so i have to use another battery to start it everytime so annoying.
Re: Flywheel?
My rally Sigma has only a 360CCA battery. No problem starting using a reduction starter after sitting idle for a month between events. In fact I recently drove it into the shed on the starter motor when I ran out of fuel. A 520CCA battery should have power to spare, or the battery is past its use by date.
Also I have real heavy duty battery leads, good quality battery terminals, plus the motor is earthed to the chassis rails on both sides of the motor. All this makes a difference, together with a 100 Amp alternator.
