Starion brakes on GK - min tickness of rotors
karl_2ltgc
Post by karl_2ltgc »
I just want to confirm starion struts will bolt in to a gk and what the min thickness of a front starion rotor is?
Also are they much of an upgrade for a street car?
Superscan811
Re: Starion brakes on GK - min tickness of rotors
Post by Superscan811 »
karl_2ltgc wrote:I just want to confirm starion struts will bolt in to a gk and what the min thickness of a front starion rotor is?
The strut tops won't fit but you would just use the GK ones.
The Starion rotor
Original Thickness is 24mm
Final thickness is 22.4mm.
karl_2ltgc wrote:Also are they much of an upgrade for a street car?
Sigma are 256mm and solid.
Starion are 256mm AND vented.
They would weigh a bit more so the unsprung mass would increase but they would be less susceptible to brake fade.
Over all, a bonus for hard driving.
Rally_2.6LC
Post by Rally_2.6LC »
Scott, just gotta find a better street legal caliper to go with them.
This is what ill be puttin on my LC, but still trying to find a legal 4 pot caliper that will fit it......might just go willwood's until i get it back on the road, but then again i just want to be able to build it, race it and then rego it.
Cheers Matt
'75 GC daily (slowly dying)
^This side up^
Formely "Matt"
Cottees
Post by Cottees »
I am in the middle of putting Starion Struts into my GN. Front struts are bolt in when you change the strut tops. Here is a pic of both a GJ-GN and Starion JA strut tops :
The rear rotors and callipers are bolt on for a Scorpion diff.
I also have done some research on GJ-GN brakes vs Starion JA brakes. As well as alternative brake pads:
http://www.sigma-galant.com/viewtopic.p ... 240#p41184
