Making a scorp handle beta, what have u done??
Posted: Sat Oct 31, 2009 5:22 pm
by Paddles
hey,
just wondering what people have done to make the handling of a scorpion better. so far i have replaced suspension with pedders sports shocks and king spring lows. lowest you can get unfortunately without cutting springs, anyone else lowered a scorp very low but legally???
ive also replaced the bushes with nolathene products and moved the strut tops inward for more camber.
i have been looking at adjustable strut tops from k-mac but i think the next up grade would be sway bars, i have found a couple of after market bars for the front but cant find a rear sway bar, pedders use to sell them but dont know??
what have people done from current and past experiences?? this car is mainly street driven but has the occasional club day around the track.
Paddles
Re: Making a scorp handle beta, what have u done??
Posted: Sun Nov 01, 2009 1:18 am
by DragonCypher
I mentioned a while ago I used 25mm bolt on spacers to fit bigger wheels
But before putting the bigger wheels on I tried the spacers with the factory wheels.. pushing the wheel out by that much gave it more bite when first turning, and held better mid corner (whereas without spacers would start to understeer earlier, was a very noticable difference on the track)
Another thing it does is make the steering a lot heavier, so without power assist, its a lot more difficult to take sharp turns at speed
But that shouldnt be a problem unless you're a woman
Also means it self centres alot more, infact almost instantly
Other than that I can only suggest wider tyres. For the weight of a scorp, around 225-235 up front would be optimal. Power steering would almost be a necessity with them though
Chris
Posted: Mon Nov 02, 2009 5:13 am
by Paddles
cheers for the reply, ill be staying away from spacers, im more thinking of after market bolt ons, sways bars, strut tops etc. i really want to lower it more without cutting the springs. most companys make lows but nothing lower.
Paddles
Posted: Wed Nov 04, 2009 7:25 pm
by Paddles
i have found a company called SELBY's, they only sell sway bars, they have sigmas/galants/scorps etc listed with standard replacements and also aftermarket sizes. has anyone used them before or heard any stories??
catalogue below::
http://www.selbys.com.au/docs/catalogues/EDS0021.pdf
Paddles
Posted: Fri Nov 20, 2009 11:59 am
by webby
Why would you want beta? VHS is sooooo much better
The usual, starion struts, selby swaybars, decent shocks, and you can get superlows for the sigmas
Or you could go the whole hog with an S13 front end and whatever people do to the tail
Posted: Tue Dec 08, 2009 11:28 am
by TUFSIG
i have front and rear shelby sway bars on my gl scorpion and heavy duty shocks with some extra neg camber on the front thing handles mad its not lowered atm but if it was it would be even better rear is solid as a rock
Posted: Mon Dec 21, 2009 8:25 pm
by Paddles
you mentioned super low springs. who sells these??? i have checked king springs, pedders, lovels etc.
as for selbys i will be buying front and rear sway bars after xmas.
Posted: Tue Dec 22, 2009 9:50 am
by webby
Any spring company, they're the 50mm lower ones I think.
Posted: Thu Dec 24, 2009 7:36 pm
by Paddles
you can buy low shocks for scorps and sigmas but no one sells super low springs for them. the only way is to get kmac or some company similar to make some, they do any height for you. the lows are 50mm lower than standard. already have them installed, i want to go lower without chopping the springs. will prob have to get some made.
these super lows, can u remember which website or company sell them if they are avaiable??
Posted: Thu Dec 24, 2009 10:27 pm
by webby
Ummmm
I saw them on Ebay
Posted: Wed Dec 30, 2009 7:26 pm
by endlss
i got white line front and rear sway bars kings and revalved shocks to match on 17's not spacers (20+) handles very well , but i got the rear sway bar with another car i brought , wouldnt go out and by one not with the solid rear these things have dont really see the point but i guess every little bit helps
Posted: Sat Jan 02, 2010 11:18 pm
by Paddles
yeah ill be upgrading the sway bars and then go from there. already done bushes springs and shocksetc. i sent a pm in regards to sway bar as well.
Paddles
Posted: Sun Jan 03, 2010 11:43 am
by Sigmaproject
The thing with springs is that they must remain captive, both for legality and safety.
Well we are probably not too concerned about the legal aspect.
But if your rego man actually jacks up your car to checks the suspension, and the spring falls out of it locating channels in the top or bottom mount, there could be an issue.
And I think that would probably happen if you lowered it more than 50mm
Best I could do (legally) getting the wagon done at a reputable suspension firm was 30mm. So I had to shorten the strut tubes and fit different inserts. Then cut the springs
Posted: Mon Jan 04, 2010 8:04 am
by Paddles
i just put some king low springs in and it was lowerd by 50mm, when i jack it up no problem with them dropping. i reckon it will prob stay as it is unless someone makes some superlows for scorps. mine is all mod plated and all legal so im going to try and keep it that way.
