Indicator question
Posted: Thu Dec 08, 2011 4:20 pm
by H8DAG8
Hi there
Don't know too much about the electrical stuff in cars.
I've got an old '84 Mitsi Sigma SE, carby.
The question(s) I've got is/are: why does my left indicator go quicker than the right? why does the right indicator sometimes stay on and then decide to flash slowly? how can I fix this? is it cheap? is it easy(ish) to do?
Would like them to be nice solid normal-speed blinks of the indicator on BOTH sides
Any help much appreciated!
EDIT: Oh also when I flick them on there's a quick noise/click before the indicators even start working; i.e. there is a delay from when I flick em on till when they go.
Re: Indicator question
Posted: Thu Dec 08, 2011 4:57 pm
by tubby
are all your globes working? if one is blown it will seed up the blinkers on that circuit.
Posted: Thu Dec 08, 2011 5:58 pm
by H8DAG8
Ah doh completely forgot to check that, will check that tomorrow that would prob explain the right one being a tad slower. However they have both always been pretty slow and the box always clicks a few times before they actually start cranking.
Will post up tomorrow if any bulbs are blown or not.
Posted: Thu Dec 08, 2011 6:02 pm
That a Sigma for you, lol. Slow blinkers go with it
Every Sigma I have been in has the weird noise you are talking about. It is hard to type the sound but here we go. BUR, BURRRRRRRRINK.
If you have a Sigma you know the noise I mean lol
Posted: Thu Dec 08, 2011 10:09 pm
by geezer101
Could be caused by different wattage globes or dirty connection. Whatever is causing it is in the right indicator circuit, so take out the globes and swap them for new ones and clean the sockets if they look grubby.
Posted: Fri Dec 09, 2011 4:55 am
by H8DAG8
Haha yea I was going to attempt to type the sound but then thought sh*t no one is going to understand it unless they've heard it before (if I'm lucky) haha!
Will be checking out the right-hand bulbs/globes today and see what I find.
So the little box/thing that makes the indicators blink, there is no way to replace/upgrade/fix/speed that up to make them blink with a little more effort?
Posted: Fri Dec 09, 2011 5:54 am
You should be able to buy a flasher can from your local auto parts store for about $5 I would think.
As far as I remember the only difference between them is if they are 3 or 4 pin. Go to a local wreckers and grab a few from different cars with the correct amount of pins to suit your car and try them our.
Posted: Fri Dec 09, 2011 9:51 am
by H8DAG8
A112H wrote:You should be able to buy a flasher can from your local auto parts store for about $5 I would think.
So with a new flasher you reckon it will flash nice and solid and fast/normal?
Checked bulbs today, all are fine.
The right-hand one also goes at the same speed as the left again now so no idea why it had a little spazz the other day.
Where abouts do I find this flasher in the cabin?
Posted: Fri Dec 09, 2011 10:03 am
by ddt
it'll be under the dash around the steering column somewhere. Just turn on your indicators and feel around under there for which relay is ticking.
Posted: Fri Dec 09, 2011 10:10 am
by H8DAG8
Ok thanks.
So will a new (or one from a more modern car) flasher definitely make the indicators tick with a little more effort?
Or is it just a guess?
Posted: Fri Dec 09, 2011 1:27 pm
by geezer101
You'll need to find the same rating flasher relay as they can sometimes be sensitive to the load on the circuit. Some may light up but not flash, others might not even close circuit and flash at all...
Posted: Fri Dec 09, 2011 1:33 pm
by H8DAG8
geezer101 wrote:You'll need to find the same rating flasher relay as they can sometimes be sensitive to the load on the circuit. Some may light up but not flash, others might not even close circuit and flash at all...
Ah I see, will the rating be on the one inside my car? Do they simply unplug or are they not able to be taken out unless you cut wires or something?
Would the Sigma manual have that info.?
Posted: Fri Dec 09, 2011 1:40 pm
by geezer101
When you pull the indicator relay out it will either be a round metal can with the load rating stamped onto the top of it or if it's a rectangular plastic cased relay it'll be printed on it. Normally the relay is just dangling under the dash next to or just above the steering column. Relays do get tired from age (they've got a spring to return a contact to it's open circuit position and the contacts also foul from doing their thing for years and years), but as ddt put it simply, turn your indicators on with your head under the dash and look for the ticking - you'll find it, no worries!
Posted: Sat Dec 10, 2011 4:26 am
by H8DAG8
Cheers mate will be doing that today.
Posted: Tue Dec 20, 2011 7:49 pm
by foxpsi
another thing to check would be condition or wiring and connections this will increase resistant and cause problems check the body earth is the bolt tight? is it corroded check the connections on the indicators are they corroded???
hope this helps a bit
Posted: Wed Dec 21, 2011 8:15 am
by H8DAG8
Thanks for the further info.
Have been flat out and haven't had time to check any of it out yet!
Will hopefully get time on these few days coming up to Xmas, or after Xmas.
Cheers guys.
