its been awhile since a update,
since my last one not much else has been done to the lancer after fixing the welsh plug no more leaks so thats plus side
on top of all the things i have to do , i thought id take the dash out , not good idea , thinking the speedo was faulty after
not checking the speedo cabel correctly first time around left with the hassel of putting it back in which is nightmare since i have
to remove the steering wheel and so forth .......
plus side got to replace some bolbs . hopfuly after this i will try and get back on track with rust repairs on the boot lip seal
ontop of this i have tj magna on the way as a daily
already knw that it need a good oil change plus flush and possable new oil pump .
ontop of a few other little things fun continues
http://youtu.be/NP8fBp_cf8c
from my reseach the sounds of bad oil flow in the lifters
i am hoping .....
![Image](http://i840.photobucket.com/albums/zz321/7thsin_2010/SAM_6597.jpg)
good as new still
![Image](http://i840.photobucket.com/albums/zz321/7thsin_2010/SAM_6598.jpg)
such a mess
next venture is going to clark rubber hopfully getting replacement window seals at a mint ......
![Image](http://i840.photobucket.com/albums/zz321/7thsin_2010/SAM_6824.jpg)
