ignition barrel
ignition barrel
Hi all does anyone know how to remove a ignition barrel from a sigma any help much appreciated regards Chris
Re: ignition barrel
Remove the steering wheel, plastic surround, and combination switch. You'll then see that the switch is attached with 2 single use security bolts. The easiest way to remove them is to cut a slot into the top with a hacksaw, then use a flat head screwdriver.
Re: ignition barrel
thanks but I have done all that how do I remove the barrel regards Chris
