All Saturn 4G30 (1300), 4G33 (1400), 4G31 (1500), 4G32 (1600), 4G35 (1750) motors are narrow block.
All Astron 4G50 (1850), 4G52 (2000) motors are narrow block
Astron 1 and 2 4G54 (2600) are both wide and narrow block. Out of the Mitsubishi factory auto is narrow, manual is wide.
Sirius 4G63 (2000) are both wide and narrow. Out of the Mitsubishi factory front drive is narrow (includes Evos), rear drive is wide.
Don't assume that your motor is wide or narrow if it is a motor that comes in both wide and narrow. Someone may have already modified it (eg converted a 2.6 auto sigma to manual, by fitting a narrow block/bell housing 5 speed).
Here are the measurements to be sure.
Wide block/bell housing is 330mm between centres
Narrow block/bell housing is 310 between centres
Just measure the distance between the centres of the 2 holes as shown in the pic below. They are the lowest bolt hole on the block, so if measuring a motor, measure there.
![Image](http://i253.photobucket.com/albums/hh62/niknikthegreat777/100_2093.jpg)
This info is useful for gearbox conversions (eg, putting a wideblock 2.6 and 5 speed into a Galant or Lancer shell that had a 1.4 or 1.6 with a 4 speed).
Gearstick positions
2.6 5 speed wide bell housing long extension 735mm from bell housing to stick base centre
2.0 or 1.6 5 speed narrow bell housing short extension 660mm from bell housing to stick base centre
2.0 or 1.6 4 speed narrow bell housing 620mm from bell housing to stick base centre
I'm also told some 2.6 5 speeds from Scorpions come in a wide bell housing with a short extension (so the measurement on that box would be 660mm I assume, I don't have one to measure).
Other threads that may be of interest or help
Bolt in RWD Engine Upgrades
Identifying: "Jap" or borg Warner box & Wide Vs. Narrow
Jap 5sp conversion info, Galant and Lancer
If anyone has more info they would like to add, feel free.
Also remember this thread if someone asks if if they have a wide or narrow block. It will save a lot of time and effort.
