Best wheel size
Best wheel size
I dont know between 13" or 14" is the best for my lancer?
Here is a picture:
http://postimage.org/
I want nice fitment and stance
Here is a picture:
Re: Best wheel size
A lot of that comes down to personal taste.
114.3 x 4 in decent offsets that aren't +38 or 0 or minus offsets are pretty hard to find.
I just recently bought these from Osaka Japan.
Fronts 15 x 6 3/8 +6.5 offset, and rears 15 x 6 1/2 +7.5 offset.
They are Rays Volk Mesh
Here's a set reasonably local to you 14 x 6.5 +10 offset (probably not bad for Lancer guards)
http://www.gumtree.com/p/cars-vans-moto ... to-content
Re: Best wheel size
I was looking into 13x7 -0 and 13x8 -7 nice split rim wheels and also was looking into 14x7 -0 all round,also split rims.
I want to be able to fill the arches nicely because of the bigger arches on mine i think i want wider than 6.5
Re: Best wheel size
This is the fitment i am looking for if anybody knows this car could they try find out wheel size please
Re: Best wheel size
The car above has rather large bolt on flares, so no doubt they're a 9" front and a 10/11" rear...
14x7 -0 and 14x8 -0 should sit very flush
N/A ALL THE WAY
- LukeAussie
Re: Best wheel size
Personally, I like 13"s, cos they're not so common these days, and even with modest spec tyres, they look fat! But 14"s do look cool too...
Re: Best wheel size
13's are fine if are running stock brakes.LukeAussie wrote:Personally, I like 13"s, cos they're not so common these days
I've only seen one set of 13's fit over Sigma front brakes though.
How's this for filling the guards
Re: Best wheel size
That looks like a very good fitment but they look very big on it, are they 15's?
Re: Best wheel size
Yep.
Re: Best wheel size
I can fit 15x8 0 offset rear and +10 on my LA with stock guards so you could go wider
with yours with flares. My 14x7 turbos fit perfectly with no stretch on tires
(unsure of offset)
(unsure of offset)
Re: Best wheel size
Thats good to know because i would love the widest wheels possible on it . Thanks for your help lads!
Re: Best wheel size
Don't remember what the offset for these 16" (and the car originally having 14" not 13")
but the front's have about a 4mm spacer behind them. Haven't had the rears off so not sure.
205 fronts & 225 rears
The most expensive car I've ever bought was a 1984 Mitsubishi... in 2014.
Re: Best wheel size
I bought these 14" SSR Longchamps
url=http://postimage.org/][/url]
Then i started to refurbish them myself
Still not sure if i am going to use them on the car or not yet!
Re: Best wheel size
What's the sizing on them other then diameter?Paul4carz wrote:I bought these 14" SSR Longchamps
Re: Best wheel size
2 fronts are 14x6 (offset not known,not wrote on them so have to measure them)
The rears are 14x7 and 14x6.5 so i am on the lookout for one 14x7 if anybody knows of one and even one 14x6.5 and then i could use 14x6.5 on front and 14x7 on back
