Battery Relocations
Battery Relocations
So im gunna move the battery to the boot in my GC and was wondering if someone could draw a up a diagram or put one together quickly with some pretty pictures and stuff hahah had a look online at a few they sorta confused me a little as they seemed more designed for newer cars
Re: Battery Relocations
Things i have as well
Like 7metres of 4GA
isolation switch 100amp
120amp safety switch
Things still gotta get
FInding a battery Box to fit my battery
Distrabution block for engine bay things
Like 7metres of 4GA
- LukeAussie
I haven't done this, but it should be a relatively straight forward task. Essentially, you need "big" cables running to the starter motor, earth (on the engine), and medium cables to the coil and alternator, and it's really a matter of connecting it like an extension lead I'm sure others on here have done it though, so hopefully they'll be more help! Good luck!
- amgis_obrut
parts used when I did my sigma
0ga cable
0ga crimp ring terminals x4
+ - forged brass battery terminals
supercheap battery box
Isolation key
0ga cable
Isolation key
i was thinking same thing bout fucking edit button and do you reckon id need 0ga or will 4 do ?
So i threw together thing diagram what you guys think should it work ?
easy. put battery in boot, run earth to body in boot, posative cable running to stater motor terminal, and main power feed wire from battery terminal to starter aswell.
At least 2ga for the Positive. You have to compensate for voltage drop across the distance from the trunk back to the front. Negative can be 4 gauge from terminal to ground point on body, then be sure to have a ground for the engine to chassis.Jordan1249 wrote:i was thinking same thing bout fucking edit button and do you reckon id need 0ga or will 4 do ?
Tim
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
88 Fiji Blue Starion
94 Montero SR
79 GE Sigma Wagon
76 Galant Coupe
92 Galant VR4
