1974 la lancer
- Location: deep in the mists of boost, far beyond the thick cloud of tyre smoke
1974 la lancer
im currently building a 1974 la lancer, the build has taken just over 2 years to get to this stage and it is almost finished.
astron2 m6 head,
wiseco 4g54b forged pistons,
argo rods,
knifebladed polished and balanced crank,
garrett gt35r, 38mm turbosmart ext. gate,
custom grind shaw cam, adjustable sprocket,
custom exhaust manifold, 3" mandel exhaust
intake manifold, ls1 75mm throttlebody,
microtech lt10s, x4 ignitor with coilpacks,
w58 supra box, ally tailshaft 1350series unis,
borgwarner diff 3.45:1, 31spline fullspool, billet axles,
front adjustable coilovers, 2link rearend,
bosch .044 efi pump, carter lift pump, rci fuel cell,
aeromotive rising rate fuel reg, 720cc injectors,
gk front slotted rotors/calipers, ford xh ute disc rearend.
all fabrication work has been done by myself with plenty of alcoholic beverages consumed.
on 27psi with c16 fuel in my previous build it made 380hp@wheels and ran 11.89@117mph, i hope for similar power results with this build only faster times.
this can be viewed on youtube,
900ber lancer walkaround
900ber lancer rev (excuse my brother for scratching his ar$e)
900ber lancer first start
also my previous car which i build in a month then continually repaired for 4 years,
11 sec sigma
astron2 m6 head,
argo rods,
11 sec sigma
1974 la lancer, 1993 gq patrol ute, 1971 Chevelle Malibu.
Re: 1974 la lancer
sounds nice mate !
welcome to the site.
you should put some pics up for all to see.
whats your location roughly ?
cheers stealth
cheers stealth
Re: 1974 la lancer
i dont know how to use computers to put up pictures, i will see if my girlfriend knows how to do it.
there is footage of the car on youtube, the names are on my first post.
- DanTurboLancer
Re: 1974 la lancer
Hey man, welcome!
Would love to see footage of it in action.
Dan
Dan
Re: 1974 la lancer
sleeper ftw yo!
she's pretty cool mate, what's she run?
Re: 1974 la lancer
Similar setup to mine. Are you in Brisbane?
Re: 1974 la lancer
i haven't run this car yet so im not sure what sort of time it would do, im hoping low 11s maybe better. i was planning on running it at willowbank next week but i may have to put that on hold as i blew head gasket in daily driver which will consume my funds for a little while.
the car is nearly complete i only have tacho to wire up and fitting thermo fan left to do, i would like to get it tuned and a wheel alignment before i run it just to make sure everything is running sweet.
Re: 1974 la lancer
thats fukin sweet
man the things id do to a car with money..
Re: 1974 la lancer
Very nice mechine.
Id love to see it go also.. But there is only to bolts holding your tail shaft to your diff..
Formerly known as QIKSIG
77 Lancer
77 Lancer
Re: 1974 la lancer
Geez man, nice work.
Love the tramp rods, oh, and gear box cross member! certainly frees up some space
Nick.
Nick.
Re: 1974 la lancer
hey nice lancer. im currently going to efi and wondering what throttlebody you are using? obviously you have a custom plenum byn the looks of things but the bottom half of the manifold is jus a Tn magna item?
Re: 1974 la lancer
Maybe you could let us know when your going out to Willowbank, would love
to see the Lancer run.......................GREAT MACHINE............................
3x la lancer 2door
2x gc galant hardtop
1x gc galant wagon
3x la lancer 2door
1x gc galant wagon
Re: 1974 la lancer
nice mate
Re: 1974 la lancer
astronturbo77 wrote:hey nice lancer. im currently going to efi and wondering what throttlebody you are using? obviously you have a custom plenum byn the looks of things but the bottom half of the manifold is jus a Tn magna item?
im using throttlebody off ls1 holden(chev) it measures 75mm butterfly. custom plenium which i made up and welded to tr magna intake manifold which has bigger ports and matches tr magna head which im also using.
there are 4, 1/2"unf bolts holding tailshaft to diff flange they should hold up no problems.
- karl_2ltgc
Re: 1974 la lancer
I like how you did the tramp bars with the bar linking the two sides of the front leaf mount
Re: 1974 la lancer
finally the lancer is at a point where i would say it is completed, (for the time being anyway). its booked in to get dyno tuned this friday, and if all goes well i will probably run it at willowbank on wednesday 29th of july.
Re: 1974 la lancer
make sure someone is there with a cam!
Re: 1974 la lancer
OMG. Serious dude on the list !
John Ruskin
John Ruskin
Re: 1974 la lancer
i took the lancer for dyno tune on the friday and the intake manifold gasket started leaking between runner one and coolant port so when it came on boost it pressurised the cooling system. i fixed that and decided to check tension on head studs because i hadnt torqued it down for the second time. i brought it back to dyno on monday after and the lancer ran up 384hp@27psi. as we took it off the dyno i noticed the head gasket had blown on the left side under cylinder one where the coolant ports run through the block. upon further investigation i found the head studs around cylinder one were loose again so i think i will be pulling the head off and replcing the head gasket. im a bit suspicious the block may be warped too. im looking into getting a multi-layer steel gasket for it.
Re: 1974 la lancer
just a bit of an up date for my lancer,
i managed to chase down a group of people that were getting a multi-layered steel head gasket made up for astron engines made by cometics usa, but after they got stuffed around for about 8 weeks with no further progress i dropped that idea and purchased a .60thou copper headgasket and just got my head back from being o-ringed. i found i had damage to the spiggot on the cam where the sprocket locates so i had that machined and sleeved as well. hopefully i will have engine assembled and running tonight then possibly dyno on friday and drags next wednesday night.
Re: 1974 la lancer
How badly damaged was the locating pin? nothing damaged?
Let us know how you get on at the dyno too....
Nick.
PS: needless to say... love your car.
Nick.
Re: 1974 la lancer
Nice looking 2link setup is that the Mcdonald brothers kit?
http://www.mcdonaldbrosracing.com.au/2linkkits.html
I am looking at putting one in my car seems to fit up nicely
Re: 1974 la lancer
Wow, how much is that kit?
That would fix all of my problems.
Also, what are your front rims off. They are 4 stud aren't they. Are they off a Toyota Hiace?
Re: 1974 la lancer
75wagon wrote:Wow, how much is that kit?
There is pricing on their website they go for just under $400.
Re: 1974 la lancer
the locating pin on cam was stuffed and hole on cam gear was damaged so we repaired that and made solid pin to press into cam. the hollow dowel pin collapsing is what caused all the damage.
i got to run lancer at willowbank last wednesday night, first run i pulled 12.04@119mph, i was shifting at around 5000rpm and had a poor 2.15sec 60foot. second run didn't go as well gearbox started to get really tight and wouldn't shift properly. by about the fourth run the gearbox was extremely noisey and was taking to long to shift. i then just concentrated on improving my 60foot times seeing as i paid entry, fuel etc. already, i managed to get down to 1.93 60foot which is ok but not anything to write home about. by the end of the night without being able to select 4th gear anymore i managed 13.1@87mph. i think automatic is what i really need but mortgage repayments won't allow me to fund that so i will perserfere with w58 supra gearbox and see how i go.
my rear end is mcdonald bros 2 link kit the chromoly one, i think around $500 from memory i can't really remember as i bought 31spline full spool off them at the same time.
my front rims are off nissan tiida 15" steelies, i cut the centres out then purchased 15"x4" roh outerband and welded the nissan centres into the bands at the right offset to clear the coilovers. i also had to skim 1mm out of centre hole to clear sigma spiggot as sigma has 68mm and nissan has 66mm spiggot. it was alot of work but i couldn't get 15"x4" rims in 4x144.3mm stud pattern with enough negative offset to clear my coilovers. i also have another pair of rims off some near new honda with same stud pattern which i will do same conversion to run m/t front runner tyres. i don't like the nissan tiida rims as much as the honda ones because the nissan centres appear to be made from material too thin.
Re: 1974 la lancer
- 77galantv6
Re: 1974 la lancer
Yep thanx for those vids.
I liked that
Seemed to track well on the strip too. Nice and straight, well done.
I liked that
