hey guys as some know the galants radiator let go on me about 2months ago and chasing a another replacement radiator cause its way to expensive to get the one that's in there re-cored. I'm not sure what the radiator that i have is out of.
its running a 2.6 and the front has already been modified to have a bigger radiator in there. please any further questions will be answer asap or any suggestions will be greatly appreciated.
regards james.
520x420x52 radiator im after !
- LukeAussie
Re: 520x420x52 radiator im after !
Hi James,
Best bet is often to take the existing machine to a radiator guy and get them to match it up. Normally it's pretty easy to get something that will fit.
Good luck!
Good luck!
Look on ebay? You can get aluminium radiators for less than the cost of a re-core. Just type in 'gallant aluminium radiator' or just 'aluminium radiator' look at where your outlet and inlet are, click on any radiator that you like the look of and look in 'users other items' and see if they list your model, or if they have the right dimensions and in/out let placement that you can fit in? I saw one for a gallant at $154 with free delivery..... bargain.... if it arrives and is less than suitable or crud quality, you complain to the seller or ebay and you will get another, and another and usually you don't have to send old ones back...
PWR radiators are the go. They make anything you want. Just give them horsepower and what the car would be for drag circuit or street.
Where are you located ive got an original galant one if your interested
I have a ford sierra ally one in my gb.just fits between the rails and cheap to buy of ebay uk.requires the use of a header tank as it has no filler cap and some hose mods to work though.
gb galant efi 2.6 track toy
gj sedan hack car
gj sedan hack car
do you have any pics of this set upwheelnut wrote:I have a ford sierra ally one in my gb.just fits between the rails and cheap to buy of ebay uk.requires the use of a header tank as it has no filler cap and some hose mods to work though.
4GB63t
the radiator i need is out of a lada niva -.- ive got a very unlikely change im going to find one..
- LukeAussie
Ha ha, you never know! A lot of the time there are matching parts between cars, so you might get lucky. Or need to go to Russia...
