4g54 to km119.
4g54 to km119.
So my plans ATM are to chuck a 4g54 into my lancer .
I have a narrow 4g54 all ready to pop straight in. One thing I'm not sure about it because some posts I read say one things others say other things.
If what I've read is correct. To bolt the narrow 4g54 nothing is required to fit it to a km119? I was made aware one of the bolt holes won't line up, but some people don't worry about it? So I don't need to change clutch or flywheel or anything etc?
Re: 4g54 to km119.
i just did a 4g63 DOHC to a km119. You will need a narrow 4g52 flywheel and clutch.
Re: 4g54 to km119.
Might be hard to get a 4g52 flywheel..
- Sigmaproject
Re: 4g54 to km119.
I don't know for sure..but wouldn't a 4g54 Magna have the same flywheel as a 4g52, both being narrow block. Someone will know.
Re: 4g54 to km119.
Apparently not , so I was told
But I would like to know why though as I thought the same thing
Cheers stealth
Cheers stealth
Re: 4g54 to km119.
Think it's got something to do with it being FWD?
Re: 4g54 to km119.
I just used the search function
And found that AH112 claims that a magna flywheel definitely can be used !
All narrow astrons use the same flywheel
Apparently!
Cheers stealth
Apparently!
Cheers stealth
Re: 4g54 to km119.
I got one lined up now. So its all good. But good to know for future references.
Re: 4g54 to km119.
btw the factory lancer starter motor will be no good. you will need the sigma starter. I bought a brand new one from repco for 140
Re: 4g54 to km119.
I have about 5 sigmas full of parts. Should have a good one kicking around.
