this is my build for my GE Sigma, i got it completely factory right down to the AM/FM radio, it has a 4g32 with a 4 speed but plans are to get a 4g63 and 5 speed in over the next few weeks
When i got is
![Image](http://i1380.photobucket.com/albums/ah188/Pquinn90/12208869_10153471610128876_5037662607531206094_n_zpslsh93hpe.jpg)
the following weekend
![Image](http://i1380.photobucket.com/albums/ah188/Pquinn90/12226920_10153471598178876_8141051275275732524_n_zpsurjmmprt.jpg)
Depends on ur definiton of "muscle"jvflash wrote:Classic Japanese Muscle??? The car was designed, built and exported from Australia.
Team of Australians went to Japan with their mock ups, and some of that team still work at MMAL. But that's as close as you get.
As for Australian Muscle Cars, I'm not sure Sigma rates a mention.
Mid 80's Nissan Skyline/Pintara strut inserts have 30mm less piston stroke than a sigma insert. The body is also shorter and will require a spacer to be dropped inside the Sigma strut body. (around 40mm from memory). The 30mm less travel may save your bacon at the front. These measurements are for the struts on my GN wagon ..78Sigma wrote:got some lowering springs yesterday, i went with cobra as i have had them in the past and always had a nice ride (softer than king springs). it has dropped it about 30-40mm both front and rear and loving it, however all springs have become un-captive and need to get shorter ones. My question is has anyone had this same problem and if so what shocks did you use? Its kind of hard to take the old ones out and take them to a local bnt or repco as it is my daily.
