2l astron in a ke 70.. some help please
- lockie94ralliart
i just bought a ke70 corolla with a 1.3 with a weber car, THe thing goes alright but i have a 2l astron out of my crashed lc lancer that is a really good and strong motor, i am thinking of putting the 2l into the corolla? any ideass anyone, cheers
Re: 2l astron in a ke 70.. some help please
Is there a 4 or 5 speed behind the 2ltr?
To say that social direction is not a product of belief is to say that
there is no intelligence. But that itself is not intelligent. You
cannot intelligently claim that there is no intelligence.
Personally, I'd try and put a Toyota engine into it. I'd look at a 4A-GE 'black top'. If you have a decent 4G52, then that would be good too. I am sure I have seen a 'rolla with a 4G54 in it, so it should be possible.
- EVL076
- S-G Veteran
lockie94ralliart wrote:i just bought a ke70 corolla with a 1.3 with a weber car, THe thing goes alright but i have a 2l astron out of my crashed lc lancer that is a really good and strong motor, i am thinking of putting the 2l into the corolla? any ideass anyone, cheers
funny thing, i brought a ksev yesterday, and i will be dropping my 2.6 EFI Turbo in to it
i will be making the engine mounts and box X member myself, it dont look like its gonna be that hard of a job really
keep us updated when you start the conversion
- lockie94ralliart
i had a 5 speed but i sold it so i will need to get another box for it, so any1 selling a 5 speed box give me a messsage, cheers broSigmaman wrote:Is there a 4 or 5 speed behind the 2ltr?
- lockie94ralliart
yeah my 4g52 went really good it has a lot of work done to it so i will try see what i can do, cheersCottees wrote:Personally, I'd try and put a Toyota engine into it. I'd look at a 4A-GE 'black top'. If you have a decent 4G52, then that would be good too. I am sure I have seen a 'rolla with a 4G54 in it, so it should be possible.
- lockie94ralliart
keep us updated when you start the conversion [/quote]
O really yeah that should be good, well my worked 4g52 should be alright then with a big weber carb,, it should be a great curcuit car when done,, mate could you get me a list of what needs to be done,, cheers mate
err, why? A relatively stock 16v 4AGE would go heaps better, and probably use less fuel too?
EDIT: I'm not trying to be discouraging, just pointing out that replacing a bunky old 4K with an equally bunky old Astron really doesn't make sense to me, especially when there's engines out there that would go in heaps easier and give better results
- EVL076
- S-G Veteran
im doing it to go a different path than the usual 4AGE, 3T etc etc
and, i also already have an injected turbo 2.6, with all the whizz bang bits
only things i will need to make are engine mounts and gearbox cross member
fuel economy is no issue as far as i am concerned
fair enough, it does get a little tiring seeing the endless stream of 4AGE's, 3T's and SR20's after a while lol
- lockie94ralliart
im only putting a 2l astron cas i have a worked motor sitting in my crashed lc lancer not being used, and iv got a ke70 rally car so i may aswell put the motor in even if it will cost me a 1000,
