Here are some pics, they can tell a thousand words..many more to come!
![Image](http://i1180.photobucket.com/albums/x402/glant1/15-08-06_1726gal-2.jpg)
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0112.jpg)
The car!
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0235.jpg)
The motor! vr4 4g63
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0232.jpg)
Did not like modified look of cast and billet alloy, soooo i painted manifold plenum in wrinkle paint then heat proof cast iron color!....^^^^
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0222.jpg)
modified fuel rail, tapped thread one end, made adapter other end, because there was not enough material to thread!!!....^^^^^^
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0219-1.jpg)
my water pipe....... thermostat housing deleted...run a remote thermostat housing in hose or..something???..CAS delete plug..^^^^^vvvv
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0218-1.jpg)
air bleed niple will go to top of radiator....^^^^^^^
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0216.jpg)
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0215.jpg)
L300 sohc pump modified to clear cam belt...ce lancer pulley?..(had good offset), yep i know its 1 groove wider,im going to run front grooves only
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0484.jpg)
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0477.jpg)
![Image](http://i1180.photobucket.com/albums/x402/glant1/IMG_0440.jpg)
sigma cross member with adapters to galant chassis rail mounts, which a remade and moved back a bit..^^^^^
![Image](http://i1180.photobucket.com/albums/x402/glant1/IMG_0437.jpg)
accelerator cable mount working well! fuel rail in place....^^^^^^^
![Image](http://i1180.photobucket.com/albums/x402/glant1/IMG_0436.jpg)
alternator relocation, left to right....^^^^^
![Image](http://i1180.photobucket.com/albums/x402/glant1/IMG_0740.jpg)
![Image](http://i1180.photobucket.com/albums/x402/glant1/IMG_0737.jpg)
modified left hand sigma engine mounts
![Image](http://i1180.photobucket.com/albums/x402/glant1/S6300992.jpg)
![Image](http://i1180.photobucket.com/albums/x402/glant1/IMG_0438.jpg)
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0443-1.jpg)
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0442.jpg)
![Image](http://i1180.photobucket.com/albums/x402/glant1/100_0230.jpg)
wolf 3d ??? hope to run crank sensor on front pulley to run this computer..
