Hi all,
What's the difference between ball joints on GA/B and GC/D. They have different part numbers (BJ116 and BJ122). I know the control arms are interchangeable (done it). Is it maybe something to do with the conical taper (into the steering arm) ?
Ball joints: GA/B vs GC/D
John Ruskin
John Ruskin
Re: Ball joints: GA/B vs GC/D
The length of the stud is different ..... GC/GD are slightly longer. The GC/GD steering knuckle is "deeper" accordingly. Not sure about the taper.
If you put a GC/GD balljoint into a GA/GB knuckle, the strut won't bolt up to it (I found this out the hard way years ago ...... took me hours to figure out what was wrong !
I haven't tried it, but I suspect a GA/GB balljoint would work in a GC/GD.
Hmmmm
Thanks. I appreciate your reply.
I have a real mix-n-match: GC control arms, GH Scorp struts and steering arms. Lovells Lows. In a GA.
Just CANNOT get rid of the -ve camber
I'll start replacing things bit by bit heading back towards standard until the prob is sorted.
John Ruskin
John Ruskin
Pretty sure the taper's are different too. Have ran into this problem a couple of times. The A/B have the smaller and the C/D with the bigger... Thats how they ment to be anyway, with the car being 30 odd years old, and i have also done is switching bits between the models so anything could be in it, best to take the steering knuckle with you when ordering the new ones.
GA/GB has a smaller 'stud' diameter than GC/GD - ie the tapered part.
I had a problem many years ago (long story) where we had to put a GC balljoint into a GB 'knuckle'/steering arm.
Took a long time with a file to make the arm fit - but bolted on OK from there.
This was about 1983 and we were using a genuine ball joint.
Gaz
Gaz
